AN_129_FTDI_Hi_Speed_USB_To_JTAG_Example.pdf
App note to setup FT2232H to use JTAG.
Adobe Portable Document Format -
486.52 kB -
10/06/2017 at 04:50
Preview
AN_124_User_Guide_For_FT_PROG.pdf
FT Prog is a program created by FTDI to aid in setting up the FT2232H chip.
1.07 MB -
10/06/2017 at 04:42
Preview
Digilent-Pmod_ Interface_Specification.pdf
PMOD Interface Specifications from Digilent. This was used when placing the PMOD connectors around the board.
131.03 kB -
05/01/2017 at 01:21
Preview
ug381- spartan 6 select io resources.pdf
3.11 MB -
04/25/2017 at 12:52
Preview
SpartanMiniSchematic.pdf
332.03 kB -
04/25/2017 at 12:51
Preview
spartan 6 pinout.pdf
14.42 MB -
04/25/2017 at 12:50
Preview
spartan 6 clock resources.pdf
3.16 MB -
04/25/2017 at 12:49
Preview
spartan 6 datasheet.pdf
3.20 MB -
04/25/2017 at 12:49
Preview
spartan 6 memory controller.pdf
2.07 MB -
04/25/2017 at 12:49
Preview
spartan 6 user guide.pdf
3.91 MB -
04/25/2017 at 12:49
Preview
spartan 6 configuration.pdf
4.31 MB -
04/25/2017 at 12:49
Preview
