Space constraints and board routing
05/18/2017 at 18:56 • 0 commentsI finally had time to get the circuit into Kicad and found all the appropriate chip footprints. The linear distance requirements of the sensor are dictating the board dimmensions. I'm running into issues with via spacing and routiing, even with the small components. It looks like I will need to test the slightly stronger model of the sensor instead Hopefully I gain a few mm of board space. Here is a picture of the madness.
Yeah I know, picture of a monitor and all...
Breadboard prototype seems to be functioning
05/11/2017 at 00:20 • 0 commentsI forgot to mention that the hall effect sensor under test is the Allegro A1318.
Link to buy the part: https://www.digikey.com/short/3nf1m2
So I first finished the pre-logic stage of the circuit and tested the output values. This was done so that I know exactly what the logic will see. Leds were used to visualize this, also I don't have six volt-meters but an 8-channel logic probe would have worked also.
Video featuring pre-logic stage
The next step involved testing with some AND logic chips. In the final version we will be using NAND chips because of the ability to sink more current than source. But since the NAND chips are a very small footprint VSSOP-8 and I don't currently have a breakout board for them, I used AND in DIP footprint. One change, not depicted in the following video, was to move the sensors closer and eliminate dead-space in the transition.
Video featuring full prototype on breadboard:
Now it's time to get all this back into EagleCad and hopefully etch a full working prototype strip. Maybe in time for Maker Faire, hopefully. Not really sure how these very small traces are going to fight me quite yet.
Stay tuned: More to follow!
Components for testing
05/08/2017 at 18:24 • 0 commentsI have recently received the order of components to breadboard the first prototype.
Initial testing has shown something interesting and unexpected. The linear voltage hall effect sensor when powered on has a baseline output of ~1.64v. If i place a North facing magnet on a surface and move it towards the sensor, the voltage output initially decreases. I decided to measure and graph the outputs. Based on the results, with the test magnet, at about 10mm the voltage breaks the 1.64v threshold. I will basically have to slightly re-think my approach and set any value above this threshold to be a valid input to the board logic. More to come soon...
Note: When dealing with SMT, always buy extra... Because somehow they end up jumping onto the floor and vanish.
Video featuring Allegro A1318 Hall effect sensor voltage threshold testing:
Schematics in progress...
04/21/2017 at 02:11 • 0 commentsCurrently working the schematics and then going to wire up a quick prototype to see if it even works.
