Hackaday.io Hackaday.io
Sign up Log in
Bluetooth Head Mount Display Rev. 2
In this new Bluetooth Head mounted display we hope to make it sleeker, slimmer, and better looking!
dylan-r-cloudDylan R. Cloud
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1.4k followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 7
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
158
0
1.4k
11
Team (2)
  • dylan-r-cloudDylan R. Cloud
  • tony-e-nazzalTony E. Nazzal
Join this project's team
hardware
ongoing project
Software
Glasses
This project was created on 04/21/2017 and last updated 2 years ago.
Description
Like the previous Project, we hope to have an OLED display controlled by an Arduino, or a Raspberry Pi Zero. The OLED display, RGB LED, and speaker are all controllable over bluetooth. The device is powered by a adafruit powerboost module connected to a small 0.7Wh lipo battery (To Be decided). The optics are a small mirrored right angle prism and a magnifying lense. The frame and casing is all 3D printed. The Arduino and or Raspberry Pi communicates with the oled display using i2c (inter-integrated circuit). The RGB LED and the speaker use the arduino's digital output pins. The display is controlled over bluetooth using a application running on an Android phone or Linux terminal!
Total cost - ??
Files
Portable Network Graphics (PNG) - 164.07 kB - 05/16/2017 at 06:13
Preview
Components
  • 2 × Zero Pi W
  • 2 × Monocular Video Display's
  • 1 × accelerometer
  • 2 × Plate beam splitter
  • 2 × Rechargeable Li-ion 18650 Battery Electronic Components / Misc. Electronic Components
View all 7 components
Project Logs
Collapse
  • 0.5 Inch OLED display driven by Arduino Pro Mini
    Tony E. Nazzal • 06/26/2017 at 23:58 • 0 comments
  • Block diagram
    Tony E. Nazzal • 05/17/2017 at 04:37 • 0 comments
  • 3D Augmented Reality glasses prototype rendering
    Tony E. Nazzal • 05/16/2017 at 05:35 • 0 comments
  • Where and what is the First pair?
    Dylan R. Cloud • 04/21/2017 at 03:24 • 1 comment
    I join Tony's project hoping to create something great, and well it happened. The Glasses were here and I showed them off and tried them out. They were a hit, I wanted to make a second version. So this is why I created this project page!
    Here is a video of the first pair of glasses ever made!
    The first pair used a APK file for the app on android and connected through a bluetooth module. You could send text that would be backwards on the OLED because it reflected on the mirror for the display to be seen in the corner of your right eye. You could also have the LED turn on (In the video) for a light in a dark space or when needed for close-up lighting needs, We hope to have more features that would be more useful than just a gadget, So please Follow, Like, Share, and comment. This insures that this project will live on!
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
2021 Hackaday Prize
Ambient lighting for any display that just works! A DIY solution that lets you extend and enhance your viewing experience!
Project Owner Contributor
Aurora: Ambient Lighting
andrew-macphersonAndrew MacPherson
Official Hackaday Prize Entry
The HMD is bluetooth enabled and compatible with both Linux and Android.
$60 bluetooth head mounted display.
An Arduino based Scrolling Text Display built using 7 x Bi-color LED Matrix modules daisy-chained together (Bluetooth + Android)
Arduino (SPI) 7 Bi-color LED Matrix Scrolling Text
nick-limNick Lim
Display text or graphics, with cool built-in fonts and animations on a 128x16 display. Easily controlled from an SPI interface.
Intelligent LED Dot Matrix Sign Display
robotbugsrobotbugs
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Bluetooth Head Mount Display Rev. 2", please tell us the reason.
Send message
Remove Member
