4+ custom bands multispectral camera based on RasPi 3 and raspi camera multiplexer with geotagging and environmental montoring capabilities
hi,
could you please share the cost of this camera kit.
Could you please share the details of multi spectral camera kit, how much it cost, what is the wavelength nm range, bandwidth it can cover.. is it Visible, NIR range..
regards
lifysignal
Hi!
I want buy this camera kit. Please contact me who can made it andriy111{@
}gmail.com
It's capable of geotag the captured images using an external GPS module.
GoMovies streaming site
Say drone moving at 12kph
Which is 12000metres/hour
Or 3.33333metres/second
10ms delay in the multiplexer = 0.010s
Displacement over 10ms=33mm (1.3”)
This is probably much smaller than the tolerance of the GPS. Also if the delay is known and predictable then it would be possible to batch edit the metadata for each stream of the images to correct for this. As to the cameras, yes I agree that filtered monochrome cameras would be better but I would love to see the results (going to test with multiple Pi Zeros myself!).
@makye the project is in hold while I get proper filters. I had good results with image registration and mosaic generation without filters, and saving raw images instead of jpg ones. Trust me, the software available now is powerful enough for that kind of processing. You can't say what does work and what doesn't without knowing the background research, and only by reading a short description and seeing a couple of photos. Problems are made to challenge us as engineers, and I as an engineer will overcome them by any means, and that's the way you apply science.
Hi Andres, in no way I'm discouraging research/science outcomes. In fact, I would love to see some meaningful results from your project. Now, based on your last post, I concluded, probably a bit early, that your project was going nowhere, or you may have dropped it altogether.
Having clarified my point, how do you describe 'good results'? How is registration 'good'? Taking into account that the multiplexer does not send commands to the cameras at the same time but, instead, it sends the commands in an orderly fashion. What is actually the latency between cameras? 7 milliseconds? My experience is that the multiplexer gives more than 10 milliseconds between cameras. That's ok if your drone stops at each waypoint and triggers the camera(s), but constant movement would be a real challenge for this type of camera to work.
Second, What sort of filters are you planning to use? short-bandpass or long bandpass? What's the centre-point of your filters? I guess you are planning to use blue, green, red and a sort of NIR filter, right? Besides, you made no mention about the camera sensors, which I guess, means that you are happy with the PiNoir cameras. If that's so, in terms of processing, what format are you saving the images on?
Lastly, can you update your post so as to reflect the real stage of your project? Can you post your registered images and mosaics? What you mean by proper filters? The ones on the pictures look ok; aren't they? what about those: https://www.andovercorp.com/products/bandpass-filters/standard/800-899nm/
Logically the project didn't work. And it didn't work because you can't use a multiplexer mounted in a moving object. These things would never trigger the camera at the same time, therefore you'll have all sort of problems with image registration, alignment and consequent mosaic production. Besides, raspberry pi cameras are colour sensors with a lot of processing happening in the background in order to give 'crisp' images. Pi Noir are colour sensors without the IR filter. You need a monochrome sensor, with good quantum efficiency after 800nm. Monochrome sensor-based cameras are not cheap because they are not produced en mass for mobile phones. If you really want to create your own multispectral camera, be ready to create your own pcb design, create drivers, and get hold of a very good monochrome sensor. In other words, buy a commercial system.
Hi Andres, did you get any result ? can you share with us?
Super interested in this project, will be watching closely!
Very interested in this project as I've been trying to work out how to do multispectral stuff for a while now. Are there any samples of the images taken by the system?
Arducam
Nick Bild
Johanna Shi
Hi,
Could you please share your information?, I would like to build a multispectral camera with raspberry and If you sell it, Can you say me How much does cost it?
Best Regards.
