Just released Visuino version 7_8_3_24
- Added STM32 Nucleo F303RE, and F401RE Boards support
- Added Analog 2D Change Distance component
- Added 4D Systems ViSi Gene Displays Smart Controls support
- Added M5Stack 8 Servos Hat
- Added M5Stack BugC Robot Hat
- Added M5Stack JoyC Dual Joystick Hat
- Added M5Stack StickC Single Joystick Hat
- Added M5Stack Mini Potentiometer Unit
- Added Holtek I2C Touch Sensor BS8112A/BS8116A
- Added YahBoom Piano BBC Micro Bit Carrier Board
- Added Waveshare ST7735 Display BBC Micro Bit Carrier Board
- Added SPI RAM component
- Added SPI Flash component
- Improved SPI EEPROM, and FRAM support
- Improved I2C support allowing visual live binding for I2C Address
- Added MicroSD, EEPROM, RAM, and Flash Storage support
- Improved RemoteXY support
- Improved Software Serial
- Improved Grove support
- Improved Infrared Remote support
- Added Text To Char conversion Added Random Quaternion component
- Improved Random Complex component
- Improved GPS support
- Added option to disable Software Reset for the Serial ESP8266
- Added Enabled property to the Graphics elements
- Improved Lines and Polygon Graphics support Added Nextion Display Angled Line Element Added ESP8266 WiFi Mac Address (BSSID) Access Point property
- Improved Micro SD support
- Added optional SPI speed setting for some of the SPI components
- Added support for reversed horizontal and vertical order of Maxim LED MAX7219 matrixes
- Added EEPROM and RAM Storage State element
- Improved Play Tone component
- Added Graphics Categories
- Added Nextion and 4D System element categoreis
- Added option to send recorded data to the GPS component for processing
- Added Serial1 support for the ATmega 32U4 boards
- Added Grove Tilt component
- Improved ESP32 support
- Improved Maple Mini support
- Improved M5Stack Button Unit component
- Reduced memory useage by some of the components
- Added more Elegoo Smart Car demos
- Improved IDE stability
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community for you to download
