Just released Visuino and Visuino Pro version 8_0_0_72
- Significantly Improved IDE Speed and user interface
- The generated code uses Less RAM
- Added option to Enable/Disable board indexes
- Added Seeeduino Wio Terminal
- Added Arduino Portenta H7
- Added Arduino UNO WiFi Rev.2 support
- Added Canaduino PLC 500 support
- Added ESP32 WeMos D1 and ESP32 WeMos D1 Mini support
- Added RP2040 RTC support
- Added RP2040 Processor Software Reset, Sleep Mode and Watchdog support
- Added SAMD Processor module
- Added STM32 Processor module
- Added Software Reset for SAMD based boards
- Added Get Processor ID operations
- Improved RP2040 USB Serial support
- Improved Teensy USB Serial support
- Improved Teensy GPIO support
- Improved Secured Sockets support
- Improved Controllino support
- Completely redesigned Teensy support without the need of Teensyduino to be installed
- Added Teensy Processor Restart and Reboot operations
- Added Analog Integrator and Differentiator components
- Added PCA9633 I2C RGB Led Controller support
- Added JHD1214 I2C LCD Display support
- Added Seeeduino Grove 16X2 LCD RGB Backlight Full Color Display support
- Added Add Value elements to the Set Value, Counter, and Rotary Encoder components
- Added support for connecting USB Keyboard and Mouse to Samd boards
- Added Random Alpha Color, and Random RGBW Alpha Color generators
- Added Ramp To Value Alpha Color, and RGBW Alpha Color components
- Added Alpha Color, and RGBW Alpha Color converters
- Added Color to RGB WColor converter component
- Improved Display Orientation support
- Added 3D to 2D Orientation converters
- Added RGBW Alpha Color support
- Added WrapArround to the 'Extract Sub Text' component, allowing easy implementation of scrolling text
- Added Clock Structure, and Package elements allowing easy RPC implementation
- Added Alpha Color, and RGBW Alpha Color Structure, and Package elements
- Added Alpha Color, and RGBW Alpha Color memory elements
- Added RGBW Color Value Array
- Added Color To RGBW Color converter
- Improved LSM6DS3 support
- Automatic components path checks at startup
- Improved Arduino Configuration dialog
- Added option to copy the HEX File Name Path for simplified usage in Proteus and other hardware simulators
- More component definitions are now made open source
- Added support for namespace attributes in the component definitions
- Simplified component definitions
- Improved automatic Board Index files support
![](https://cdn.hackaday.io/images/9608901649781099087.jpg)
again,
is it better than ardublocks ?.. it occurs to me its one thing to glue various blocks together and quite another when U need the f/w to do something that U are not sure how to implement in the first place! Having trouble phrasing this, but u probably know what i mean..
It is best to download and try the free version ;-) . Visuino is completely different concept that Ardublocks ;-) . It is a whole different ball game ;-)
and the all up real $cost? pls!
There is free version, there is a standard version for $39 and there is a Professional version for $199.
You can use the free version for fair number of projects, so it depends on the complexity of the projects.
where is it??
You can download from www.visuino.com :-)
