Just released Visuino and Visuino Pro version 8_0_0_125
- Improved Infrared Remote Transmitter and Receiver components
- Redesigned and significantly improved Play Station 2 Controller support
- Improved Play Station 2 Cytron Shield support
- Added Keyestudio Servo Driver Shield with a Play Station 2 Port support
- Improved ESP32 3.0.X support
- Improved support for Analog reference
- Improved ESP32 Touch support
- Improved Analog Integrator
- Improved Arduino UNO R4 support
- Improved Adafruit Motor Driver Shield V1 implementation
- Improved Arduino MKR boards support
- Improved support for Voltage Reference based components
- Added Adafruit Motor Driver Shield V2 both as Shield and Component
- Added Honeywell Pressure Sensor MPR/MPRLS I2C and SPI components
- Added Vishay Ambient Light Sensor TEMT6000 component
- Added U-Blox M8 GPS I2C and Serial components
- Added Adafruit Mini Gamepad with Seesaw (I2C) component
- Added Arduino MKR ENV Shield rev2
- Added Arduino MKR GPS Shield
- Added Arduino MKR Ethernet Shield
- Added Adafruit Data Logger Shield
- Added RGB Ultrasonic Ranger component
- Added Adafruit Joy Featherwing as Shield and Component
- Added Adafruit Stepper + DC Motor FeatherWing as Shield and Component
- Added Adafruit Ethernet FeatherWing
- Added Arduino Portenta C33 support
- Added Arduino Zero support
- Added Waveshare RP2040-Matrix RGB 5×5 board support
- Added Waveshare RP2040-Zero board support
- Added Waveshare RP2040-One board support
- Added Generic ESP32 C6 support
- Added ESP32 C6 Development Kit C-1 support
- Added Nano ESP32 C6 support
- Added Generic ESP32 H2 support
- Added ESP32 H2 Development Kit M-1 support
- Added Renault Kangoo Battery (CanBus) component
- Added Renault Kangoo Battery Source/Simulator (CanBus) component
- Added Dataq YF-S201 Flow Sensorcomponent
- Added Microchip Digital To Analog Converter (DAC) – MCP4728 (I2C) component
- Added Acebott Quadruped Bionic Spider Robot Shield
- Added Temperature and Humidity Sensor HTU31D (I2C) component
- Added TSCINBUNY Omni Directional Robot Shield
- Improved 4D System Displays support
- Improved DFRobot Serial MP3 Player support
- Improved PlayStation 2(PS2) Controller (Serial Shield) support
- Improved IDE
