Just released Visuino version 7_8_3_9
- A Completely Free Mode of Visuino now available for entry level users and students
- Added VL53L0X Laser Ranger component
- Added Texas Instruments ADS1100 self-calibrating Analog-to-Digital (A/D) converter component
- Added DHT12 Thermometer and Humidity sensor component
- Added M5Stack ENV Unit component
- Added Analog, Color, RGBW Color, Date/Time, Digital, Integer, Text, Char, Clock, and Unsigned Demux components
- Improved RemoteXY Graph design support
- Improved Controllino PLC RS485 support
- Improved Industrial Shields RS485 Serial
- Improved Text Memory Element
- Improved BME280 and BMP280 component
- Improved Nextion component
- Improved ESP32 support
- Improved Value Array component
- Reduced memory usage by the Serial channels
- Reduced memory usage by some of the components
- Some IDE stability improvements
