Just released Visuino and Visuino Pro version 8_0_0_112
![](https://cdn.hackaday.io/images/56821711757184741.png)
- Added Arduino UNO R4 WiFi support
- Added Arduino UNO R4 Minima support
- Added the option to send breaks, and have improved the RS485 support
- Added initial support for QWIIC/STEMMA interfaces
- Added proper pin mapping to all Serial and SPI interfaces, for boards that support mapping
- Added Silicognition RP2040-Shim
- Added Adafruit Metro RP2040
- Added Unsigned Array components
- Added Complex Math components
- Improved CAN bus support
- Added CAN bus shields support
- Added CAN bus filter components
- Added ESP32 CAN bus support
- Arduino UNO R3 moved to pure text definition
- Added support for sending Breaks over the Serial ports
- Improved RS485 Serial support
- Added option to Disable any processor element
- Improved Grove support
- Added WakeUp by pins, and touch support for ESP32, ESP32 S2 and ESP32 S3
- Added STM32 RTC support
- Added option to Disable Value Source Elements
- Added Add Complex
- Added Add Complex Value
- vSubtract Complex Value
- Added Subtract From Complex Value
- Added Multiply Complex By Analog Value
- Added Multiply Analog By Complex Value
- Added Divide Analog Value by Complex
- Added Divide Complex by Complex Value
- Added Divide Complex Value
- Added Conjugate Complex
- Added CAN bus Value
- Added Binary To CAN bus
- Added CAN bus To Binary
- Added CAN bus Multi-Source Merger
- Added CAN bus Multi Source
- Repeat CAN bus
- Added CAN bus On/Off Switch
- Added CAN bus Toggle Switch
- Added CAN bus Demux(Multiple Output channel Switch)
- Added CAN bus Toggle Demux
- Added CAN bus Mux(Multi channel Switch)
- Added CAN bus Snapshot
- Added CAN bus Array
- Added Unsigned Array Delete Items
- Added Unsigned Array Insert Items
- Added Unsigned Array Replace Items At Index
- Added Unsigned Array Snapshot
- Added Remember Unsigned Array
- Added Step/Iterate Unsigned Array Items
- Added Get Unsigned Array Item At Index
- Added Unsigned Array Value
- Added Unsigned To Unsigned Array
- Added Unsigned Array Change Only
- Added Unsigned Array Mux(Multi channel Switch)
- Added Unsigned Array On/Off Switch
- Added Unsigned Array Toggle Switch
- Added Unsigned Array Demux(Multiple Output channel Switch)
- Added Repeat Unsigned Array
- Added Generic TM1637 7 Segment Display 6 Digits Module component
- Added DIY More TM1637 7 Segment Display 6 Digits Module component
- Improved Detect Edge(Digital to Clock) component implementation
- Added Arduino 4 Relays Shield
- Added HiLetgo 4 Relays Shield
- Added Generic Multi Function Shield
- Added Unsigned Array Package/Structure elements
- Improved M5Stack CoreS3 support
- Improved 74HC595 Shift Register support
- Added 74HC595 Shift Register 8 Digits 7 Segment Display support
- Added Complex To Complex Array
- Added Analog Array Change Only
- Added Analog Array Multi Source
- Added Complex Array Change Only
- Added Complex Array Multi Source
- Added Analog Array Mux(Multi channel Switch)
- Added Analog Array On/Off Switch
- Added Analog Array Toggle Switch
- Added Analog Array Toggle Demux
- Added Analog Array Demux(Multiple Output channel Switch)
- Added Repeat Analog Array
- Added Complex Array Mux(Multi channel Switch)
- Added Complex Array On/Off Switch
- Added Complex Array Toggle Switch
- Added Complex Array Toggle Demux
- Added Complex Array Demux(Multiple Output channel Switch)
- Added Repeat Complex Array components
- Added 64 bit Unsigned filter components
- Deprecated the old Dynamic 7 Segment Display components
- Added Improved Dynamic 7 Segment Display support
- Improved Digispark support
- Redesigned array and binary data components to improve performance, and reduce memory usage
- Improved On/Off delay component
- Improved M5 Stack ATOM Matrix support
- Improved Waveshare RP2040-Matrix RGB 5×5 Matrix support
- Improved bpi:bit (ESP32) support
- Added STM32 Generic STM32L031K6 support
- Added STM32 Nucleo-32 STM32L031K6 support
- Improved SubDiagrams support
- This version also for first time officially includes signed installer
The Visuino Pro and the Visuino SDK are available on the Download page:
https://www.visuino.com/downloads
Please enjoy!
