Just released Visuino and Visuino Pro - 8_0_0_23 with Raspberry Pi Pico RP2040, Arduino MKR ZERO support, brand new open source components, and much more...
06/07/2021 at 06:02 • 0 commentsJust released Visuino and Visuino Pro version 8_0_0_23
- Completely redesigned to use brand new easy ti implement pure text component definitions
- Complete redesign of most of the components to use the new text definitions
- All text defined components are now made open source
- Improved IDE Speed and user interface
- Added Raspberry Pi Pico RP2040 support
- Added Adafruit Feather RP2040 support
- Added Adafruit ItsyBitsy RP2040 support
- Added Pimoroni Tiny 2040 support
- Added Adafruit QT Py 2040 support
- Added SparkFun Micro Pro - RP2040 support
- Added SparkFun Thing Plus - RP2040 support
- Added Generic RP2040 Board support
- Added Arduino MKR ZERO support
- Added Atmel SAMD21 RTC support
- Added Adafruit ItsyBitsy 32u4 - 5V support
- Added Adafruit ItsyBitsy 32u4 - 3V support
- Added Adafruit ItsyBitsy M0 Express support
- Added Adafruit ItsyBitsy M4 Express support
- Added Adafruit QT Py - SAMD21 support
- Added Seeeduino XIAO support
- Added Adafruit Feather HUZZAH32 support
- Added Teensy 4.1 support
- Added Sunfounder Sloth Robot support
- Improved Adafruit Feather M0 support
- Added Bedac - PLC-DIO A13/7 as board
- Added Makerfabs MakePython ESP32 support
- Added INA3221, INA260, INA226, INA230 and INA231 Voltage/Current/Power modules support
- Improved Infrared Remote support
- Improved ML8511 UV Light sensor support
- Improved BNO055 support
- Improved ESPCopter support
Just released Visuino and Visuino Pro - 8_0_0_0 with RGBDuino support, up to 60 times faster project cloading and much more...
11/26/2020 at 18:57 • 0 commentsJust released Visuino and Visuino Pro version 8_0_0_0
- Up to 60 Times faster loading of big projects in the IDE
- Significantly improved IDE Speed and user interface
- Added RGBDuino support
- Improved Interrupt support for ESP8266 and ESP32
- Added visual live binding for I2C Address value
Improved GPS implementation - Improved ViSi Genie 4D Systems support
- Added visual live binding for ViSi Genie 4D Systems element indexes
- Improved UDP Socket
- Improved TCP Server Socket
- Improved support for M5Stack NeoPixel modules
the generated code
Just released Visuino and Visuino Pro - 7_8_3_64 with significantly improved Raspberry Pi and much more...
08/24/2020 at 18:06 • 0 commentsJust released Visuino and Visuino Pro version 7_8_3_64
- Added Raspberry Pi Console and Sockets support
- Added TTGO T-Display ESP32 support
- Added ST7789 Display support
- Added support for the 4DOF Manipulator Potentiometer and Servos Shield
- Added Reverse for the all the Servo components and elements
- Improved RemoteXY support
- Added support for the Optic Flow PMW3901 sensor
- Added initial Video and Image Processing support
- Added STM32 RTC Support
- Added UV Light Sensor Lapis ML8511 support
- Added ESP8285 support
- Improved Controllino support
- Added EndOnNewLine, and Ending text elements to the Char To Text component
- Improved STM32 Support
- Added Interval Output Pin to the Sequence
- Added Sonoff Smart Socket S26 (ESP8266)
- Added ESP-01 Temperature/Humidity DHT11 Shield support
- Added ESP-01 Thermometer Maxim 1-Wire Thermometer (DS1820/DS18S20/DS18B20) Shield support
- Added CJMCU-407 STM32 board support
- Added STM32F4VE board support
- Added Generic STM32F407VG, and STM32F407VE support
- Added DF Robot Beetle ESP32 support
- Improved Sockets support
- Improved JY901 Attitude Angle Sensor support
- Improved Teensy RTC support
- Improved Maxim 1-Wire Thermometer (DS1820/DS18S20/DS18B20) support
- Improved performance of some of the Graphics displays
- Improved ESP8266 OTA - Programming over WiFi implementation
- Improved Color support
- Improved Categories organization
- Redesigned the Visuino IDE toolbar
- Significantly improved Build, Upload and Libraries Management in the IDE
Just released Visuino and Visuino Pro - 7_8_3_58 with new builtin Compilation, Upload, Boards and Libraries management and much more...
06/25/2020 at 23:25 • 0 commentsJust released Visuino and Visuino Pro version 7_8_3_58
- Brand new builtin compile and upload support without the need for the Arduino IDE
- Brand new automatic and manual Platforms and Libraries management
- Added Arduino Nano 33 BLE and Arduino Nano 33 BLE Sense support
- Added HTTP Client component
- Added DIY More ESP32 HiGrow support
- Added DIY More ESP8266 Strong support
- Added DIY More NANO Strong support
- Added LIS3MDL 3-Axis Magnetometer
- Added APDS9960 Proximity, Light, RGB, and Gesture Sensor
- Added LPS22HB Pressure sensor
- Added HTS221 Temperature/Humidity sensor
- Added RemoteXY Sound
- Added M5Stack Vibration Motor Unit component
- Added M5Stack Mini Fan Unit component
- Added M5Stack RS485 to TTL Unit component
- Improved PID component
- Improved Speed To Clock/Direction component
- Improved User Interface
- Improved Text Splitter support
- Improved Server Socket implementation
- Improved MQTT support
- Improved I2C EEPROM component
- Improved Arduino DUE support
- Improved Interrupts support - significantly reduced memory usage, and improved speed
- Improved RemoteXY LED support
- Significantly improved Rotary Encoder component
- Improved EVK-NINA-B1 pin mapping
- Improved IDE stability
- Improved Custom Component component
- Significantly faster IDE when working with big projects
Just released Visuino and Officially Visuino Pro - 7_8_3_43 with CANbus, M5Stack Atom support and much more...
03/13/2020 at 17:21 • 0 commentsJust released Visuino version 7_8_3_43
VISUINO PRO IS NOW OFFICIALLY RELEASED!
- Added initial CANbus support
- Added MCP2515 support
- Added Text Parser/Splitter component
- Improved ESP32 support
- Improved Controllino RS485 support
- Added TTGO-T4 ESP32 (V1.3) support
- Added ESP8266-01 Shields support
- Added ESP8266-01 Simple Relay Shield
- Added ESP8266-01 LC Technology Serial Relay Shield
- Added ESP8266-01 LC Technology 2 Relays Shield
- Added ESP8266-01 LC Technology 4 Relays Shield
- Added TTGO-T18 ESP32 (V1.0) support
- Added MPU6886 Accelerometer Gyroscope component
- Added M5Stack ATOM Lite support
- Added M5Stack ATOM Matrix support
- Added M5Stack StickC new version support
- Added BeginText, EndText, SeparatorText, and ElementPrefix properties for the Binary To Text component
- Improved Nextion Display Multi Page support
- Added the option to use ###strong#< without index for the Formatted Text
- Added M5Stack Laser Transmitter Unit
- Added M5Stack Optocoupler Unit
- Added M5Stack Photoresistor Unit
- Added M5Stack EarthMoisture Unit
- Added M5Stack StickC Card Keyboard Hat
- Fixed bug in the Inverse component
- Added Most Significant First property to the Make, and Split Structure components
- Added Timeout Timer component
- Added Electricity Meter EMH Metering ED300L Serial component
- Added ILI9341 Display Inverted property
- Added SPISpeed property to multiple SPI components
- Improved Formatted Text component significantly reducing memory usage and improving speed
- Improved Flash storage support
- Improved M5Stack StickC JoyC Hat support
- Improved Macetech RBM Shades support
- Improved Clock Modified component
- Improved MicroSD card support
- Improved Arduino Micro Pro support
- Improved ESP8266-01 support
Just released Visuino - 7_8_3_24 with STM32 Nucleo F303RE, and F401RE Boards support support and much more...
01/02/2020 at 03:06 • 0 commentsJust released Visuino version 7_8_3_24
- Added STM32 Nucleo F303RE, and F401RE Boards support
- Added Analog 2D Change Distance component
- Added 4D Systems ViSi Gene Displays Smart Controls support
- Added M5Stack 8 Servos Hat
- Added M5Stack BugC Robot Hat
- Added M5Stack JoyC Dual Joystick Hat
- Added M5Stack StickC Single Joystick Hat
- Added M5Stack Mini Potentiometer Unit
- Added Holtek I2C Touch Sensor BS8112A/BS8116A
- Added YahBoom Piano BBC Micro Bit Carrier Board
- Added Waveshare ST7735 Display BBC Micro Bit Carrier Board
- Added SPI RAM component
- Added SPI Flash component
- Improved SPI EEPROM, and FRAM support
- Improved I2C support allowing visual live binding for I2C Address
- Added MicroSD, EEPROM, RAM, and Flash Storage support
- Improved Software Serial
- Improved Grove support
- Added Text To Char conversion Added Random Quaternion component
- Improved Random Complex component
- Improved GPS support
- Added option to disable Software Reset for the Serial ESP8266
- Added Enabled property to the Graphics elements
- Improved Lines and Polygon Graphics support Added Nextion Display Angled Line Element Added ESP8266 WiFi Mac Address (BSSID) Access Point property
- Improved Micro SD support
- Added optional SPI speed setting for some of the SPI components
- Added support for reversed horizontal and vertical order of Maxim LED MAX7219 matrixes
- Added EEPROM and RAM Storage State element
- Improved Play Tone component
- Added Graphics Categories
- Added Nextion and 4D System element categoreis
- Added option to send recorded data to the GPS component for processing
- Added Serial1 support for the ATmega 32U4 boards
- Added Grove Tilt component
- Improved Maple Mini support
- Improved M5Stack Button Unit component
- Reduced memory useage by some of the components
- Added more Elegoo Smart Car demos
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community for you to download
Just released version 7_8_3_20 with expanded M5Stack, SeeedStudio Grove System support and more...
12/03/2019 at 00:06 • 0 commentsJust released Visuino version 7_8_3_20
- Added Quaternions support
- Added Complex To Analog and Quaternion To Analog components
- Improved Signal Generator design
- Added SHT20 Temperature Humidity component
- Added Arduino Sleep modes
- Improved Shift Register support
- Improved M5 Stack Stick C support
- Improved Grove System support
- Improved NeoPixels support
- Improved GPS/NavSpark support
- Improved DHT12 I2C component
- Improved Time Setting elements
- Added ESP32 Light Sleep element
- Added M5Stack Laser Ranging Grove Unit VL53L0X component
- Added M5Stack Stick C Yun Hat
- Added M5Stack Stick C ADC ADS1100 Hat
- Added M5Stack Stick C DAC MCP4725 Hat
- Added M5Stack Stick C Infrared Thermometer MLX90614 Hat
- Added M5Stack Stick C Ranging VL53L0X Hat
- Added M5Stack Extended IO PCA9554 Unit component
- Added M5Stack Serial GPS Unit component
- Added M5Stack DAC Unit MCP4725
- Added Infrared Temperature Sensor Unit MLX90614
- Added M5Stack ADC Unit ADS1100
- Added M5Stack Accelerometer Unit ADXL345 component
- Added M5Stack Color Sensor RGB Unit TCS3472 component
- Added M5Stack Mini Relay Unit
- Added M5Stack Mini Button Unit
- Added M5Stack Keyboard Unit
- Added M5Stack Makey Capacitive Touch Unit
- Added Texas Instruments TCA9548A I2C Switch component
- Added M5Stack I2C Expansion Unit TCA9548A component
- Added M5Stack RGB LED Unit component
- Added M5Stack HEX RGB LED Board component
Just released version 7_8_3_16 with expanded M5Stack support and more...
11/08/2019 at 04:41 • 0 commentsJust released Visuino version 7_8_3_16
- Added KocoaFab Orange Board BLE support
- Added TM1637 and TM1638 support
- Improved SeeedStudio Grove System support
- Added BMM150 support
- Added PCA9554 support
- Added SeeedStudio Grove System Generic Digital and Analog Input components
- Added SeeedStudio Grove System Generic Digital Output component
- Added SeeedStudio Grove System Relay, Button, and Touch components
- Added M5Stack Dual Button Unit component
- Added M5Stack Joystick Unit component
- Added M5Stack PIR Motion Sensor Unit component
- Added M5Stack StickC Environment Hat
Just released version 7_8_3_14 with expanded M5Stack support and more...
10/25/2019 at 05:29 • 0 commentsJust released Visuino version 7_8_3_14
- Improved Elegoo Penguin Bot support
- Improved JSON
- Added M5Stack Stick C Speaker Hat support
- Added Split Digits component
- Added LIS3DH component
- Added ADXL345 component
- Added TCS3472 component
- Added Adafruit Circuit Playground Express support
- Improved Adafruit Circuit Playground Clasic support
- Improved BNO055 component
- Added Clock Modify component
- Added Max Step to the Ramp To Analog Value component
- Significantly improved graphics speed and alpha rendering support
- Improved M5Stack Stick C Display support
- Improved RemoteXY component
- Added Graphics Render Event element
- Added Toggle Demux components
- Added MicroSD Repeat Read element
- Improved support for LCD Display custom characters
- Added SPI Speed for the ILI9341 Display
- Added Reset Display property to the Nextion display making it easier to use it with Nextion Simulator
- Improved Improved NRF52832 BLE support
- Improved Teensy Analog Inputs support
- Some IDE stability improvements
