It works!
01/02/2018 at 07:04 • 0 commentsFinally got around to finishing the firmware for this and it works!
Still need to get USB DFU working and tweak the encoder sampling.
Initial Laser Cuts are Here!
06/03/2017 at 17:55 • 0 commentsThe 3mm thick acrylic cuts for the enclosure have arrived from Pololu, and it seems everything's fitting together nicely. Just waiting for the 6mm cuts now.
Encoder and Neopixel Test
04/24/2017 at 16:25 • 0 commentsMy PCBs are finally back from the DirtyPCBs fab and the quality is surprisingly excellent! I soldered one up, and the USB, encoders, and Neopixels all seem to be working nicely. The encoder inputs still had a little bounce despite the analog debounce filter I put in, which was a little disappointing. I wrote up a quick and flexible debounce service for the encoders and buttons here, instead.
Hylian
