We are still working on the project. The new PCBs are running quite well. So a first prototype might be coming in the next weeks.
We are now fixed with four steppers for each PCB. So each bigger clock should have a horizontal number of individual clocks, which can be divided by four. For the smallest version of 24 clocks it fits perfectly and for any bigger one this shouldn't also be a problem.
How did you find x40 reference point? The same small 1x2 mm magnets with hall effect sensor?
Can you show a picture of setup?
I follow you now for some months and hope to see your 24 face prototype soon :-) What is the advantage to go with CAN compared to I2C communication? My project is build up with I2C as this was the easiest for me :-) As beginner in this topic, I didn't wanted to try other bus systems. But if there are better alternatives, I would be interested in. My approach is with an ESP32 as master and ATMEGA328 as slaves. Cost not a lot and works well. However, the I2C communication seems not to be 100% reliable, sometimes a handle get a wrong command??? So I would be interested to see the CAN alternative - if there are significant advantages.
I2C is only made for short distances, like within the same PCB. If you think about a large array of individual clocks the distance between the master and slave PCBs can go up to more than 2 meters. With I2C it's propably only possible by using level shifters and set the signal to 12-15V. This may work, but I2C is still not made for these long lines.
I agree. I almost went with rs-485 since it is almost unidirectional, but you basically need a physical layer that is long distance capable.
I’m working on basically the same project. I’m also using can to address master boards with a micro driving 4 motors- just finished laying it out. I did elect to make each board seperate for each motor and run cable to each motor via ribbon cable for control.
Any reason you chose the stm32? I was going to roll my own Microcontroller board but I found it was cheaper to buy arduino nanos for $1...
The STM32 as bluepill is also available for less than $2 and it has more memory space and CAN directly implemented. Also there are two SPI and two I2C. So more options for fancy additions...
I ordered them at PCPWay, but any Chinese producer can do this. They are "only" 405mm wide. The steppers are a little bit noisy. For a clock with more than 100 faces it really could make some noise. So lets see, what the prototype with 24 faces will show to us.
Yeah, they all do it. But at their own rates :) That's why I asked... But looking at your BOM, the PCBs sure aren't the most expensive part hehe
Wow, those PCBs are huge! Where did you order them? DirtyPCB?
Anyways, smooth rotation of the steppers, are they noisy?
