The construction of a SPDT relay using basic construction materials. Cardboard, paper, paper fasteners and household castoffs a la the cardboard computer IO. This project is to prove to me that if all else fails in our world that I and others can roll our own electronic and electrical components. It is ugly to be sure and can use more R&D but even in a raw state, it works very well. I was also inspired to build this after following the project Relayreprap.
Looks like I might have a use for relays with my #The Cardboard Computer - IO is my name project after all. I am looking into ways to interface IOs output to a converted typewriter and need isolation while still using materials/parts that are on hand here in my secret lab :-) Need 16 SPST relays, just need to get the coil current demands down to a manageable level.
Here is the coil for relay number 2. Using double thickness of cardboard at each end and turned 90 deg. for strength.
Here is the result the morning of March 21, 2018...
The counter weights for breaking the contact will be replaced by a spring or rubber band. Better core material is on the horizon.
As of this afternoon, IO and the printer both are using the relay as isolation and working well.
Not far from the truth Yann :-) I plan on treating the panel as ROM and still need to wire up the panel read logic. Each pad is one nibble and should track with the PC. Jez has recommended that I could try wiring it as a stack and shift four bits as needed for reading so could go either way :-)
my vote you have
