One key keyboard
There was a project with a three key keyboard, then a project with a two key keyboard. This is a one key keyboard!
0 followers
As mention in the summary, a three and two key keyboard have been featured. I had the idea for an absolutly useless project that is a one key keyboard. Although with the current implementation it may have some use in teaching binary, hex and ascii.
I am building (have built) the keyboard using the following (non) extensive list of components.
Arduino Nano
128x128 Oled
A button!
A breadboard
Hookup wire
Some electricity
kb.mov
Little movie showing that it does actually work!
quicktime - 5.01 MB - 06/12/2017 at 09:39
Download
_1buttonkb.ino
Sketch
ino - 4.08 kB - 06/12/2017 at 09:03
Download
Schematic
JPEG Image - 604.24 kB - 06/12/2017 at 08:54
Preview
  • 1 × arduino Nano (With CH340)
  • 1 × Freetronics Oled display - 128x128
  • 1 × Button
  • 1 × ABout 10-12 hookup cables
  • 1 × Breadboard
  • Project is Finished!
    Stan06/12/2017 at 09:02 0 comments
    Well it is finished!
    I have uploaded a schematic and shortly will upload the sketch and if I can a short video!
    To use:
    You input 7 bit's of a byte (the first bit is always zero - 7 bit ascii). Essentially the bottom right will blink either a zero or a 1. When the bit you want is shown, push the button and the bit will be added to the byte being collected. When you have a full byte, it is sent out on pin D8 - any input comes in on pin D9 (I may have these reversed). As I am just using this for loopback, Instead of SoftwareSerial, I had to use AltsoftSerial which allows full duplex TX/RX.
    What you send appears on the top line and what is received comes back on the line under that. Special characters are decoded to <SI> <CR> etc.
    It works - and will teach you binary - but I STRONGLY suggest a ascii/binary chart will be needed in the early stages.
    As I say - completely useless - but does work!
    Stan
  • Log the second
    Stan05/01/2017 at 21:54 0 comments
    FInally got time to do some more work. (Wife was working a late shift). Got the actual keyboard working now entering 7 bit binary and displaying actual ascii (including special character codes).
    Todo:
    1. Link to Raspberry pi echo program.
    2. Display sent/received data
    3. Minor fix for the 'do I want this character or not.
    4. Schematics and doco.
  • Log the first!
    Stan04/26/2017 at 04:16 0 comments
    This was on Anzac day - wife was at work.
    Plugged in brand new nano into Mac.
    Mac paniced!
    Lots of screwing around with CH340 drivers but eventually got it going.
    Downloaded basic test - Blink ** Passed**
    Wired up Oled and tested **Passed**
    Wired up button and did some basic tests **Passed**
    Started writing code - working fairly well - but still some minor bugs.
    TODO.
    Chase bugs down.
    Link to Raspberry pi serial port for basic echo test
    Take pictures and upload
    Produce schematic and upload
    Upload sketch
View all 3 project logs
