RGB LED & LDR double insulated from any light with heat shrink tubing and almost ready for PWM - I used common anode(in my case - Arduino Due) As the board reboots, I get all the lights ON 'clipping' until the server connects to the board.
TODO: find the best LED resistor values for 3.3v & 5v
Variable Resistor used in GinScope for vRef. Can you see it? :D
https://hackaday.io/project/19374-ginscope-oscilloscope
GinLab = GinScope, GinGen etc - Program ∑ Control ∑ Run!
