Make "Uber Potentiometer" by using 2x LEDs & LDRs
A---|\/\/\/\/|---TAP ---|\/\/\/\/|---B
Move not only the TAP between A & B, but change the resistance of the POT itself !
Easy Variable Gain OpAmp control?
[ In the quest of making programmable Lab ]
First use case: controllable vRef for Adc
todo: test it in signal chain
