Foam body design
04/26/2017 at 17:39 • 0 commentsInitially, the body was made from insulation foam, just because it was easy to work with and it was what i had on hand.
However, this design proved weak in the middle. Also, i learned that the barrel needs to stay above the trigger, otherwise the gun is awkward to hold.
Prototype
04/26/2017 at 16:49 • 0 commentsFirst up i prototyped the circuit to see of it works with the parts that i was able to source.
Edit
Everything worked well but the coil needed work.
