To start this project, I am releasing complete CAD files for a V6 airsoft gearbox compliant as best as I can achieve with the outer dimensions of a CYMA V6 gearbox which itself is a clone of the Tokyo Marui V6 gearbox.
The V6 CAD files do not contain minute details nor internal gears, spring or piston, only the outer dimesions of the shell, nozzle and trigger mechanisms and motor have been modeled. This is to allow for the CAD files to be used for designing a custom AEG from scratch with the capability of using a drop in V6 gearbox bought online. Any AEG cad files build around this model when 3d printed or cnc fabricated, should work with most drop in V6 gearboxes on the market.
Anyone know if there is a more complete version of this... trying to design replacement parts as they are very difficult to find.
download?
you sir are a good person and just saved me a lot of time in my ambitious project, hats off to you.
