back.stl
backplate has a 'clip' which should hold the charge/protect board. This needs reworking the pegs were designed to push though the pcb and into the front parts, but it turns out they are too difficult to print, so back to the drawing board there
Standard Tesselated Geometry -
2.99 MB -
05/18/2017 at 08:45
Download
top_original.stl
this bit is spot on, just cradles the top of the screen nicely
787.39 kB -
05/18/2017 at 08:45
Download
buttons2.stl
the 2 little buttons for the font plate, tied together for simplicity. nice and basic
1.09 MB -
05/18/2017 at 08:45
Download
bottom_original.stl
This covers the bottom half of the font of the device. needs slight rework on cable exit for the power, and the joystick hole is a touch small. might need adjustment on the screen edging, seems a touch off
821.57 kB -
05/18/2017 at 08:45
Download
buttons_original.stl
this a top for the 5 way navigation switch, needs a spot of rework on the mounting on the bottom, its a bit too snug
591.39 kB -
05/18/2017 at 08:45
Download
