I'm waiting for the parts for the first "production" batch of the PewPew Lite boards — just around 20-30 of them, to sell on Tindie. The LED matrices just arrived from the usual Aliexpress seller, and I decided to use one in an older prototype. Turns out that a green LED in one of the corners is dead.
Since the pins are responsible for whole rows or columns, it can't be a bad connection. That really made me nervous, so I quickly assembled a testing rig for those matrices and tested all 30 of them:
I found one more faulty matrix, this time one pixel is noticeably darker than the others. All the other matrices seem to be fine. Caveat emptor.
Nice project. Made In China 's fault.
I wouldn't say it's their fault. They intentionally skip the quality control stop to make the products cheaper, and that's a tradeoff I agree to implicitly when ordering the cheapest offer. If anything, the fault is mine, for not testing the parts previously.
I'm a bit confused, is the PewPew Lite basically a Wemos D1 mini shield?
because the page before it's a feather wing o.O
The PewPew Lite is a FeatherWing. This is an earlier prototype using a D1 Mini to run CircuitPython, which I have abandoned, because it requires you to install drivers, doesn't show up as a USB drive and doesn't have a battery charger circuit — so it's less suitable for the particular use cases that I have in mind.
