Back to overview
Analyzing plant health with near-infrared imagery
Wifi Raspberry Pi Touch screen camera
1. Use this link for PiTFT RESISTIVE TOUCH screens2. Download Jessie Lite-based PiTFT 2.4", 2.8" and 3.2" Resistive Image for Pi 1,2,3 Zero
3. Format a 4GB or larger SD card and load it up with the Raspbian operating system.4. Install Camera
5. Testing cd adafruit-pi-cam-master
sudo python cam.py
Error---------
pi@picam:~/adafruit-pi-cam-master $ sudo python cam.py
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
Traceback (most recent call last):
File "cam.py", line 572, in
camera = picamera.PiCamera()
File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 431, in __init__
self._init_camera(camera_num, stereo_mode, stereo_decimate)
File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 460, in _init_camera
"Camera is not enabled. Try running 'sudo raspi-config' "
picamera.exc.PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
4. Install Camera
5. Testing
sudo python cam.py
Error
