Schematic
A microcomputer with PS/2 keyboard, SD card storage and composite video output, running Terminal-BASIC
Schematic
I try to do some 3D wireframe graphics with Terminal-BASIC matrix operations:
The source is in the Terminal-BASIC team repository:
10 REM 3D rotations using matrix operations
20 REM FILL TABLES OF SIN AND COS
30 DIM SC(1,255)
40 LET D = 2.*PI()/256.
50 LET A = 0
60 FOR I%=0 TO 255
65 A = A + D
70 SC(0,I%) = SIN(A)
80 SC(1,I%) = COS(A)
90 NEXT I%
100 REM Octahedron
110 DIM V1(2,0), V1W(2,0)
120 V1(0,0) = 0 : V1(1,0) = 0 : V1(2,0) = 40
125 MAT V1W = V1
130 DIM V2(2,0), V2W(2,0)
140 V2(0,0) = -25 : V2(1,0) = 25 : V2(2,0) = 0
145 MAT V2W = V2
150 DIM V3(2,0), V3W(2,0)
160 V3(0,0) = -25 : V3(1,0) = -25 : V3(2,0) = 0
165 MAT V3W = V3
170 DIM V4(2,0), V4W(2,0)
180 V4(0,0) = 25 : V4(1,0) = -25 : V4(2,0) = 0
185 MAT V4W = V4
190 DIM V5(2,0), V5W(2,0)
200 V5(0,0) = 25 : V5(1,0) = 25 : V5(2,0) = 0
205 MAT V5W = V5
210 DIM V6(2,0), V6W(2,0)
220 V6(0,0) = 0 : V6(1,0) = 0 : V6(2,0) = -40
230 MAT V6W = V6
300 REM screen coordinates
320 DIM VS1(1), VS2(1), VS3(1), VS4(1), VS5(2), VS6(2)
330 LET A% = 0 : LET B%=0 : LET C%=0
340 DIM RMX(2,2) : MAT RMX = IDN
350 DIM RMY(2,2) : MAT RMY = IDN
360 DIM RMZ(2,2) : MAT RMZ = IDN
370 DIM RM(2,2)
380 GOSUB 1100 : GOSUB 1200 : GOSUB 1300
1000 REM main loop
1010 K$ = INKEY$()
1020 IF K$ = "d" THEN A% = A% + 1 : GOSUB 1100
1030 IF K$ = "a" THEN A% = A% - 1 : GOSUB 1100
1040 IF K$ = "w" THEN B% = B% + 1 : GOSUB 1200
1050 IF K$ = "s" THEN B% = B% - 1 : GOSUB 1200
1060 IF K$ = "e" THEN C% = C% + 1 : GOSUB 1300
1070 IF K$ = "q" THEN C% = C% - 1 : GOSUB 1300
1080 GOTO 1000
1100 REM Update rot matrix z
1110 IF A%<0 THEN A%=255
1120 IF A%>255 THEN A%=0
1130 RMZ(0,0) = SC(1,A%) : RMZ(0,1) = -SC(0,A%)
1140 RMZ(1,0) = SC(0,A%) : RMZ(1,1) = SC(1,A%)
1150 GOSUB 1400
1160 GOSUB 9000 : GOSUB 10000
1170 RETURN
1200 REM Update rot matrix x
1210 IF B%<0 THEN B%=255
1220 IF B%>255 THEN B%=0
1230 RMX(1,1) = SC(1,B%) : RMX(1,2) = -SC(0,B%)
1240 RMX(2,1) = SC(0,B%) : RMX(2,2) = SC(1,B%)
1250 GOSUB 1400
1260 GOSUB 9000 : GOSUB 10000
1270 RETURN
1300 REM Update rot matrix y
1310 IF C%<0 THEN C%=255
1320 IF C%>255 THEN C%=0
1330 RMY(0,0) = SC(1,C%) : RMY(0,2) = SC(0,C%)
1340 RMY(2,0) = -SC(0,C%) : RMY(2,2) = SC(1,C%)
1350 GOSUB 1400
1360 GOSUB 9000 : GOSUB 10000
1370 RETURN
1400 REM Rotate points
1410 MAT RM = RMX * RMY
1420 MAT RM = RM * RMZ
1440 MAT V1W = RM*V1 : MAT V2W = RM*V2
1450 MAT V3W = RM*V3 : MAT V4W = RM*V4
1460 MAT V5W = RM*V5 : MAT V6W = RM*V6
1470 RETURN
1990 END
9000 REM procedure to project
9010 VS1(0) = V1W(0,0)+100 : VS1(1) = -V1W(2,0)+90
9020 VS2(0) = V2W(0,0)+100 : VS2(1) = -V2W(2,0)+90
9030 VS3(0) = V3W(0,0)+100 : VS3(1) = -V3W(2,0)+90
9040 VS4(0) = V4W(0,0)+100 : VS4(1) = -V4W(2,0)+90
9050 VS5(0) = V5W(0,0)+100 : VS5(1) = -V5W(2,0)+90
9060 VS6(0) = V6W(0,0)+100 : VS6(1) = -V6W(2,0)+90
10000 REM procedure to draw figure
10005 CLS
10010 LINE VS1(0),VS1(1),VS2(0),VS2(1)
10020 LINE VS1(0),VS1(1),VS3(0),VS3(1)
10030 LINE VS1(0),VS1(1),VS4(0),VS4(1)
10040 LINE VS1(0),VS1(1),VS5(0),VS5(1)
10050 LINE VS2(0),VS2(1),VS3(0),VS3(1)
10060 LINE VS3(0),VS3(1),VS4(0),VS4(1)
10070 LINE VS4(0),VS4(1),VS5(0),VS5(1)
10080 LINE VS5(0),VS5(1),VS2(0),VS2(1)
10090 LINE VS6(0),VS6(1),VS2(0),VS2(1)
10100 LINE VS6(0),VS6(1),VS3(0),VS3(1)
10110 LINE VS6(0),VS6(1),VS4(0),VS4(1)
10120 LINE VS6(0),VS6(1),VS5(0),VS5(1)
10190 RETURN
New software, I'v just built, based on Terminal-BASIC 2.1-b1. It uses russian lexems, because the computer is used by my 5 years old daughter, who don't understand English and still can't read latin alphabet. Also I use my new ps/2 keyboard Arduino library, from https://bitbucket.org/starling13/libps2 . This library supports locales switching and controls the keyboard LEDs, as can be seen on the photo.
Terminal-BASIC 2.0-rc introduced UNIX-style file operations. This video shows the process of loading 1-bpp BMP file from SD-card. Yes, it's damn slow. Image was loaded by the following BASIC program:
1 DEF FN BN% (BYT%, BIT%) = (BYT% \ (2 ^ BIT%)) AND 1
10 INPUT F$
20 GOSUB 1000
100 END
1000 REM LOAD
1010 BMP% = FOPEN ( F$ )
1020 IF BMP% = - 1 THEN PRINT "FOPEN" : GOTO 1995
1030 B% = FREAD ( BMP% ) : M% = FREAD ( BMP% )
1040 S$ = CHR$ ( B% ) + CHR$ ( M% )
1050 IF S$ <> "BM" THEN PRINT "HEADER" : GOTO 1990
1060 FOR I% = 1 TO 8 : B% = FREAD ( BMP% ) : NEXT I%
1070 DP% = FREAD ( BMP% )
1080 DP% = DP% + FREAD ( BMP% ) * 256
1085 DP%=DP%-12
1090 IF DP% < 0 GOTO 1110
1100 FOR I%=0 TO DP%-1 : B%=FREAD(BMP%) : NEXT I%
1110 FOR Y%=191 TO 0 STEP -1
1120 FOR X%=0 TO 24
1130 B% = FREAD(BMP%)
1140 FOR XX%=0 TO 7
1150 POINTC X%*8+XX%, Y%, FN BN%(B%,7-XX%)
1600 NEXT XX%
1700 NEXT X%
1710 B%=FREAD(BMP%):B%=FREAD(BMP%):B%=FREAD(BMP%)
1800 NEXT Y%
1990 FCLOSE BMP%
1991 S$=GET$()
1992 IF S$="" GOTO 1991
1995 RETURN
This computers firmware is a variant of my Terminal-BASIC. It suffers from heavy weight, due to my limited abilities and C++ it's written in, but it is important for me as the window in the world of language translators and learning desk.
But I start to think about the alternative firmware, which is a compromise between the simplicity and flexibility. It will be based on Z80 CPU emulator.
On the host side there will be a piece of C++ code. First component is an interactive monitor, allowing to view/modify the Z80 emulator ram, load and store ram portions to or from SD card, may be some assemble/disassemble in the future. The second component is a Z80 emulator calls library, allowing to call the native C++ functions from the z80 code.
The main purpose of this firmware is the ability to write programs in C, using sdcc for z80, store multiple programs to SD card and run it without reprogramming the Arduino flash.
Unlike great projects, running CP/M emulator on Arduino DUE, this approach gives the ability to use the boards with a cople kilobytes of RAM to run simple programs, as long as CP/M will not run with less then 64k RAM, and more need to an emulator itself.
Compared to the Terminal-BASIC, which allows to run programs from SD card too, I expect, compiled C code, running in Z80 emulator to be much faster.
I'v published the sources of BASIC-microcomputer emulator for PC. It runs on Linux and depends on posixcpp and SDL2 libraries.
It can be used to debug major parts of BASIC-microcomputer firmware (terminal-basic interpreter, TVoutEx library etc.) and to test what BASIC-microcomputer can do.
Minimal BASIC test programs, tetris game and other test programs can be found here.
Yes, it needs a configuration to utilize TVout library-based output. I also recomend to use the version of terminal-basic, which I actually run on this device. If things will work, it's worth to try recent one.
Try version 2.2.2.
It appears that in the 2.3 branch, which introduces hierarchical configuration, TVOut output never supported.
In the file config.hpp setup TVOUT output:
// Input select
#define S_INPUT SERIALL_I
// Output select
#MFB LPF EVAL TVOUT_O
#if USE_EXTEEPROM
Also I was forced to manually copy the "sys" directory from terminal-basic sketch to TvOutEx library "src" directory.
Nice computer you have there. I made Dan's single chip computer with graphics, sound, external joystick, integrated keyboard and everything inside handheld wooden case, where only one cable leads to TV. I have made several programs and soon I'm out of removable eeproms. It is time to upgrade. You are only one who has TVout-library (I quess?) and SD-card at the same time. Dan wrote about issues with SD, still I must try it. I already ordered SD-module and 16Mb card for it. Do you have any advice for me and may I contact you later for any upcoming questions?
I tested terminal-basic with ATmega1284 single chip computer (https://www.youtube.com/watch?v=0uTYnNounNI#action=share) but without SD card. This item uses Arduino MEGA. I think the issue with SD card and Dan's computer is in that some pins. need to use SD card, are used in his design.
Feel free to contact me as your work will have a progress.
Pins are used by eeprom. I would leave eeprom off completely when using SD-card and have it use internal 4k memory instead. He has code for this included. I'll wait for china-snail-mail to arrive and see what are the first results out of the box if I try unedited Dan's code. I'll contact you then :)
Yes, this project runs well on DUE. No problems were detected at startup. Also, all the functions of this interpreter are modular, which allows you to customize it for yourself.
I really like this project, very interested in this version of BASIC, I've been using TinyBASIC in my Arduino Computer projects, but it's very limited.
I wonder if this project could be replicated with an Arduino Due, with it's 96K of RAM and a SPI based SD adaptor.
Nice project. ;-)
Andrey Skvortsov
agp.cooper
land-boards.com
Lee Hart
is the code from SourceForge ready to run on a TV out or is there changes in the code I need to do? it seems to me it is set up for connection to a terminal running on my compuer.
