1Step 1
#include <Servo.h>
Servo myservo1,myservo2, myservo3,myservo4; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
int gyroPin = 3; //tiltmeter VTI SCA610 inclinometer chip (accelerometer)
int gyroPin2 = 5; //tiltmeter VTI SCA610 inclinometer chip (accelerometer)
int fRServo,fLServo,rRServo,rLServo;
int frontTilt;
int sideTilt;
int lowBoy = 1;
// this routine controls the speed of the servo
void myServo(int newAngle,int angleInc,int incDelay,int servoNum) {
int curAngle;
if (servoNum== 1) { curAngle = myservo1.read(); }
if (servoNum== 2) { curAngle = myservo2.read(); }
if (servoNum== 3) { curAngle = myservo3.read(); }
if (servoNum== 4) { curAngle = myservo4.read(); }
if (curAngle < newAngle) {
for(int angle=curAngle;angle < newAngle;angle += angleInc) {
if (servoNum == 1) myservo1.write(angle);
if (servoNum == 2) myservo2.write(angle);
if (servoNum == 3) myservo3.write(angle);
if (servoNum == 4) myservo4.write(angle);
delay(incDelay); }
else if (curAngle > newAngle) {
for(int angle=curAngle;angle > newAngle;angle -= angleInc) {
delay(incDelay); }
int readTilt() {
int gyroVal = analogRead(gyroPin);
gyroVal = map(gyroVal, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
delay(10);
Serial.print(" front : ");Serial.println(gyroVal);
return(gyroVal);
} // end readTilt()
int readTilt2() { // sideTilt
int gyroVal2 = analogRead(gyroPin2);
gyroVal2 = map(gyroVal2, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
delay(10);
Serial.print(" side : ");Serial.println(gyroVal2);
return(gyroVal2);
} // end readTilt()
void setup()
Serial.begin(9600);
delay(100);
myservo1.attach(3); // attaches the servo on pin 3 to the servo object
myservo1.write(90);
delay(500); // waits for the servo to get there
myservo2.attach(5); // attaches the servo on pin 5 to the servo object
myservo2.write(90); // sets the servo position according to the scaled value
myservo3.attach(7); // attaches the servo on pin 5 to the servo object
myservo3.write(90); // sets the servo position according to the scaled value
myservo4.attach(9); // attaches the servo on pin 5 to the servo object
myservo4.write(90); // sets the servo position according to the scaled value
delay(1000); // waits for the servo to get there
if (lowBoy) { fRServo = 90; fLServo = 90; rRServo = 90; rLServo = 90;
myServo(0,1,5,1);myServo(0,1,5,2);myServo(0,1,5,3);myServo(0,1,5,4); delay(5000);}
else { fRServo = 10; fLServo = 10; rRServo = 10; rLServo = 10;}
// wheel servo order: right front is 1
// left front is 2
// left rear is 3
// right rear is 4
void loop() {
frontTilt = readTilt();
sideTilt = readTilt2();
if (frontTilt > 85 && sideTilt < 90) {
// front right is lowest point
if ( rLServo < 110) { // lower opposite wheelheight
rLServo = rLServo + 2;
myServo(rLServo,1,5,3);
if ( rLServo >= 110 && fLServo > 0) { // raise downward wheel
fRServo = fRServo - 2;
myServo(fRServo,1,5,1); }
if (frontTilt < 85 && sideTilt > 90) {
// rear left is lowest point
//Serial.print(" fRServo : ");Serial.println(fRServo);
if ( fRServo < 110) { // lower opposite wheel height
fRServo = fRServo + 2;
if ( rLServo >= 0 && fRServo >= 110) { // raise downward wheel height
rLServo = rLServo - 2;
myServo(rLServo,1,5,3); }
if (frontTilt > 85 && sideTilt > 90) {
// front left is lowest point
if ( rRServo < 110) { // lower opposite wheel
rRServo = rRServo + 2;
myServo(rRServo,1,5,4);
if ( rRServo >= 110 && fRServo > 0) { // raise downward wheel height
fLServo = fLServo - 2;
myServo(fLServo,1,5,2); }
if (frontTilt < 85 && sideTilt < 90) {
// rear right is lowest point
if ( fLServo < 110) { // lower opposite wheel
fLServo = fLServo + 2;
if ( rRServo >= 0 && fLServo >= 110) { // raise downward wheel height
rRServo = rRServo - 2;
myServo(rRServo,1,5,4); }
// exit(0); //pause program - hit reset to continue
jimrd
