Yann's Leaderboard dataset was in JSON format, but CSV was needed in order to make the interactive charts, so I wrote a small Python script to convert the file format and also attach the file date/time as a new field in the dataset.
The script is in the github repository, in the 'tools' folder: https://github.com/RoGeorge/2017HackadayPrize_Stats/tree/master/tools/jsonToCsvAndAddFileTime
I should rename the files to make better timestamps...
No problem with that, thank you very much for collecting and publishing those files.
