The case size is 7cm x 4cm x 2cm
GPS tracker based on the Atmega328 using a GPS Module, a LiPo USB charger, a micro SD and RGB leds.
I created the github repo containing all the datasheets, Arduino Code and basic explanation. I will keep updating in the next few days.
I just created the project ! I made some test, everything works well ! I am waiting for the WS2812 leds to arrive (they are missing on the project pictures) and I will probably post a video to show how it looks like .
To come : Schematic, PCB, Code and Docs to come on github soon.
Hello,
Sorry for the delay, I was quite busy. Regarding the load sharing circuit, I got some inspiration from here : http://blog.zakkemble.co.uk/a-lithium-battery-charger-with-load-sharing/
When the charger is working, IN+ is 5V so the circuit uses the usb power. The problem with regulators is the dropout voltage. This charger is for one cell only meaning 4.2V at best and down to ~3.3V. unless you can get a really low dropout regulator or your circuit requires less than 3.3V, I don't think it is a good idea.
-David
