Project Finished! (for the time being)
07/23/2017 at 11:29 • 0 commentsFirst of all, I added a BOM with links in the GIT repo. I landed below the goal of 150 Euro, but mostly because a lot of stuff was free or had already been lying around my workshop for years.
As the two planned events for which SARAH was made came, she had proven herself worthy. The rough circumstances of a music festival did not do any harm to her. Battery capacity is a total overkill. From fully charged (16.8 V) to about 15.8 V after the festival, which is still well over the nominal voltage. Battery spec lists about 10 V as minimum, I programmed the MCU to switch of at 12 V.
As there are no more events for SARAH planned this year, I will mark the project as finished. Maybe next year, before the next festival, I add things like LED lights and stuff.
It was a fun little project. SARAH was very valuable on the two events! The best thing is that she became a humanized part of our group, everybody knows who SARAH is. :)
USB Connectors
07/05/2017 at 21:18 • 0 commentsOne more of the targeted features is now done and working: The USB connectors.
I used a configuration which should allow android systems to charge with a higher then standard current (up to 2.1 A depending on the cable). This means D- and D+ are shorted and on a voltage of 1.2 V (10k and 33k resistors).
On the inside I used a USB cable usually used in PCs. Since these are meant to be mounted on thin metal, i had to drill a pretty large holes so that the USB cables fit. I 3D printed two plates to close the holes.
The DC/DC is mounted next to the rest of the electronics, shown in the picture below.
The wheels on the box...
06/15/2017 at 17:31 • 0 commentshopefully make my life easier!
Since my experience at the Hack 'n Tell at the Munich CCC I know that the thing might be a little to heavy for longer transport with muscle power (alone). So I added wheels!
2 standard wheels and 2 with integrated brakes my dad had lying around:
Which gives me a new idea: under car illumination!
I have some water resistant RGB LED stripes lying around, so next step including these with some nice color changes. This is now an absolutly important requirement for SARAH!
Another add is an FM antenna for the radio:
Also I added a DC/DC Converter for the car radio, I will update the description and schematics soon.
Skip logs, updated description and details
05/10/2017 at 19:52 • 0 commentsI was a little lazy with keeping up with the logs. A added a lot of details, photos and files!
For the remaining open points I hope to remember to write build logs ;)
Design decisions
05/02/2017 at 12:35 • 0 commentsAfter collecting the above requirements, i started to plan on how to achieve these goals:
Portable
It should be small enough, so one person can carry it. Since one destination will be a music festival, also two people carrying it alongside other stuff can be possible. So not wider than 50 cm and with handles on each side.
Long battery life (>15 hrs)
I do not have that much experience in scaling battery size. Therefore i will go with, the more the merrier.
The budget limit would be very problematic, but fortunately i have several big battery packs from a dismantled Formula Student race car. More on that later., but it saved me the big bucks in Li-Po batteries.Strong housing
Since my father is a hobby-carpenter and my girlfriend a hobby-painter, I outsourced the housing to him and painting the box at the end to her. I will however plan everything in CAD before starting any construction.
High connectivity (USB, Aux cable, Bluetooth), Decent maximum volume, Budget around 150 EUR
These together have puzzled me for some time. I made the conclusion that i good compromise will be a car radio. This way i do not have to build everything from scratch (no experience in audio amplifier construction).
A nice new car radio with two or four speaker should be enough to cover all three requirements.
Additional features could include: USB outlets, lighting for tent/hut, FM radio reception
Throwing in some 5 V converter, a connector for some sort of LED lamp and an antenna for the car radio will not be that hard.
That should be enough to get some parts and start drawing some schematics!
Doubleyou
