Earth Magnetic Field NMR
I am trying to build simple NMR using Arduino, Raspberry pi, prepolarization coil, transceiver coil and op-amp for RF gain
Here is the publication, that I will be using as a reference for design, I am also planing to add gradient coil to check the feasibilty of acquring images.
http://iopscience.iop.org/article/10.1088/0957-0233/21/10/105902
Simon W Manley wrote 08/11/2018 at 01:48 point
I found Professor Michal's paper you reference very useful in working up an EF-NMR project. Also the background information on the Terranova-MRI machine from the New Zealand company, Magritek (http://www.magritek.com/products/terranova/). Some great videos on the site explaining basic theory, pulse sequences, etc.
I wrote up my practical experiences with a successful project in Chapter 8 of the book, Discovering the Quantum, for the Amazon Kindle platform ( ASIN: B07B4XTRGY  ), which is available from Amazon.com at the token price of $1.99.
The biggest problems proved to be interference from harmonics of the mains frequency and the inhomogeneity of the earth's field in a suburban environment due to steel in appliances and reinforced concrete buildings.
Michael Tayler wrote 05/10/2017 at 20:51 point
What are your plans?  Do you want to replicate the spectrometer described in the paper or modify the design significantly?  Also, ultimately, what do you want to use the spectrometer for?
Jaquen Haghaar wrote 05/15/2017 at 16:12 point
Right now, I am just trying to replicate the design to get some experience. Once I get confidence, I will try to add gradient coil to build imaging system. My plan is to use it to measure relaxation times (T1, T2) from the different samples including some biological samples.
