Hackaday.io Hackaday.io
Sign up Log in
Alpha Centauri
Big Alphanumeric Display Board – A pile of ultra-bright palm-sized 16-segment alphanumeric displays with network-based control
ben-pattersonBen Patterson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
154
0
0
0
Team (1)
  • ben-pattersonBen Patterson
Join this project's team
  • Similar project
  • ShiftPWM library
  • Similar project
hardware
ongoing project
led pwm shift registers arduino ethernet
This project was created on 05/03/2017 and last updated 9 years ago.
Description
This one has been sitting in a box for years. At the time I wasn't entirely sure how to power these huge and bright displays, but I did get the ideas around control right.
Using high power output shift registers, the 128 segments can be individually controlled from a single set of data, clock and enable pins.
Prototyping with the Freetronics Ethernet, an Arduino reference design with WizNet ethernet control is custom built into pluggable, multi-purpose modules supporting open lighting control protocols.
Components
  • 16 × TPIC6B595 Power Logic 8-Bit Shift Register
  • 8 × BL-S230B-12 LED NUMERIC DISPLAY Ultra White
Project Logs
Collapse
  • Fixing Shift Register Instability
    Ben Patterson • 05/11/2017 at 12:06 • 0 comments
    Such a simple fix! It occured to me that I had left the Shift Register Clear pin floating. Tying it high (active low) immediately stabilised the output and reduced flicker to imperceivable levels!
View project log
Log In/Sign up to comment
Sign up with Github
OR
Hackaday Prize 2019
Affordable photography tool used to capture images of bullets with no apparent motion blur
Project Owner Contributor
Edgerton, A High-Speed LED Flash
tyler-gerritsenTyler Gerritsen
Just another coin-size, wide input voltage range, low cost, failsafe, high power LED driver.
Glighter-S
enricoEnrico
In this tutorial, I am going to talk about the PC817 Optocoupler which is one of the most common and inexpensive 4-pin optocouplers.
All About PC817 Optocoupler
hulkHulk
The 2017 Hackaday Prize
Project where I put logs and other useful informations from past workshops
Electronics Workshops Resources
yann-guidon-ygdesYann Guidon / YGDES
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Alpha Centauri ", please tell us the reason.
Send message
Remove Member
