Frame, Part II
06/27/2017 at 22:14 • 0 commentsBecause we wanted this project to be relatively cheap, we used an old office desk to make our frame. This didn't cost us a single penny ^^
About the axle; we used an old steel tubing that we turned to the right dimensions so we could put the wheels and bearings on it. As you can see in the picture above, it fits !! At this point we've already made the mounting bracket for the disk brake disk (made from PVC stock).
Now that the axle is done, we can start working on the power transmission. We haven't added the motor and pinion gears yet, but we'll leave a link *here* for the future project log about that specific topic.
We decided to use only one driven wheel as the tricycle was kinda wide, and we didn't really want to use a differential transmission system.
Because the rear wheels we're using have an embedded bearing we have to make a sort of bracket to drive the wheel from the axle. The wheels themselves have a sort of "eight-armed-star-shape" casted in the plastic (as you can see in the first picture), probably for strength as these wheels are made for trolleys; so we had to engineer a part to accommodate for that. The picture below shows the milling of the notches in the PVC part.
The principle is simple. The notches in the milled part fit inside and around the wheel's inner "arms", while the part itself is fixed on the transmission axle. It may be overkill, but hey, we had access to the tools for that, so why not use them ? :p
Speaking about overkill, to get a nearly-perfect alignment of the notches, we used a manual "fourth axis" dividing plate, just because we could :D
The piece of table we used was originally square, and one side was interfering with the main axle and axle parts (mainly the disk brake). To solve this problem we chopped one side of the square frame and moved the chopped piece to the front a little, so we could put the axle where we wanted and still keep the rigidity.
Here's a picture of the finished frame with everything we've made so far attached :
Now you may be wondering about the stiffness of rectangular metal tubing, and to be honest, we are too :3 After standing on the partly finished frame, we determined that the stiffness was nice and got the "Good enough" seal of approval.
.---. ________________ /o o\ | Good enough !! | __(= " =)__ <_________________| //\'-=-'/\\ ) (_ / `"=-._ / \ ``"=. / / \ \ `=..--. ___/ / \ \___ _, , `\ `-----' `""""`'-----``"""` \ \_/ `-`
Steering, part two
06/27/2017 at 20:20 • 0 commentsRemember that wheelbarrow wheel I had laying around? Well, the tyre was flat, and I was too lazy to fix it. However, I found another good one in a junk pile in my old college, plus an old steel coat hanger support, which will come in handy for the handlebar.
We machined a steering support held by two pillow blocks (20 and 25mm in diameter, I had those laying around), bolted into a 1/4in steel plate.
The handlebar will be bolted on the thickest part (through a piece of pipe that fits over the coat hanger support) of this rotating axle, the lower, thinner part will be connected to the wheel. The wheelbarrow wheel is held by a hand-bent flat piece of steel, welded on another steel cylinder we machined to fit this lower part.
The steel plate is then welded onto a square tube and onto the frame itself.
An old table frame was also recovered in the process, along with a classroom chair, @Frédéric Druppel will mention it in the next log :)
Shopping list
05/16/2017 at 09:05 • 0 commentsNow that we have our design almost set, let's look for the other parts:
- Frame: metal tubing. Will probably buy this off my local provider
- Wheels: @Frédéric Druppel received the rear wheels. I may have a wheelbarrow wheel that may just do the trick for the front.
- Bearings: Just ordered two 20mm bearings with pillow blocks. Will need another for the engine
- Sprockets/chains: not ordered yet, we may try to go into scrapyards
- Brakes: A disk brake+caliper has been ordered , bought one of those chinesium brakes for 10 european pesos
- Steel/Aluminium(/PVC?) stock. Might get some scraps off my college, worst case I can buy some from my provider, again.
- Seat: I may still have something laying around...
That's all for now!
Frame
05/08/2017 at 12:11 • 0 commentsProbably a square rear end, front will converge into a single point to hold the fork for the single front wheel.
To be continued.
Dem wheels & sprockets
05/07/2017 at 09:33 • 0 commentsAfter a late, long chat with Manoel about which wheels we where going to use, we found some interesting links to where we could buy some.
Here they are (I also posted them for us in case we forget them) :
1st idea https://www.befr.ebay.be/itm/300919651560
2nd idea https://www.befr.ebay.be/itm/370376940748
4th idea https://www.amazon.fr/dp/B01N5HPB9P/ref=cm_sw_r_cp_api_ztTdzb2RNPE28
The 4th one is probably the one we'll end up using, as it's cheap and, well because it's cheap.
For the sprockets, we'll firs search in a scrapyard or something, but of we don't find anything, we'll probably buy some of those : http://www.befr.ebay.be/itm/35-Chain-Sprocket-9-10-11-12-13-14-15-16T-Pitch-9-525mm-For-3-8-35-06B-Chain-/152473406789?var=&hash=item23801f8d45:m:mYVo2KnvnOnbpvRAAwq5r4Q
The shaft diameter will most probably be 20mm
That's all folks !
The clutch
05/03/2017 at 13:16 • 1 commentIf we feel like complicating things, we may look at a relatively simple yet really effective system : the double-cone clutch.
It's a bit more effective than a belt-tensioning system, but harder to make, but it's a kind of challenge ^^
there's a nice website to calculate the optimum dimensions and stuff for the needed application (well kind of) (link)
We'll see ¯\_(ツ)_/¯
image courtesy of here
Rear part
05/03/2017 at 12:59 • 0 commentsTwo wheels, one free, the other one connected to the engine.
Clutch can either be integrated on the engine (if using chainsaw engine), or a simple belt tensioning system.
Things are getting a tad clearer.
Driveshaft and wheels
The wheels should be decided by now, and will use a 20mm shaft. This helps a lot designing the driveshaft itself. Now, we can't drive both rear wheels, as it'll be a problem whenever we'll take a turn. Instead, only one wheel will be coupled to the driveshaft (through a custom coupler), the other one will just sit on its bearings and spin freely.
The entire shaft should be held through two bearings on pillow blocks, pretty easy to bolt onto the frame.
Engine
We'll probably end up using a Husqvarna 165RX engine, 65cm³, about 3HP. Pretty light for that power. We'll have to adapt something on the output shaft.
The engine's backplate looks like this:
I'll probably find some tubing that adapts on this coupling. It'll be directly welded on a square pipe. The output shaft (press-fit onto the clutch bell) will go through it, and will be held by a couple of bearings with pillow blocks.
Second choice would be a Stihl 25cc engine: less poweful, but with the right gear ratio, we might have enough torque to push it up to 10km/h...
Transmission
The power from the engine shaft is transmitted to the wheels through a sprocket. Probably something like this.
The sprocket's size on the drive shaft has yet to be determined, but apparently a 5:1 ratio seems sound (according to this source). A custom coupler will have to be turned on the mill to match the 20mm driveshaft.
We'll try to use a T8F chain, widespread standard (and it's metric!). That or a #35 chain, seens to be pretty cheap too. @Frédéric Druppel also has a #40 sprocket, we'll have to choose between those three possibilities.
Braking
Another "urgent" (ahah) matter. eBay provides lots of cheap disc brakes and calipers for bikes, for around 10€... Another small coupler will have to be turned to mount it onto the driveshaft.
As for now, the priority is set on the rear shaft itself: the wheels, the axis, the bearings and the braking system.
Front part
05/03/2017 at 12:57 • 0 commentsGood thing with a tricycle: steering is easy. Bad thing: it's unstable.
Was thinking a simple bike wheel on an axis.
More to come
