Its been a bit slow of late
01/06/2015 at 00:58 • 0 commentsI've not updated this project in while as I've been busily building our house (out of strawbale) so its ready for the arrival of our first child (any day now).
I first started this project because its what I need to help manage my gardens and live stock around the farm. So it will be completed (or at least usable) in the next 6 months. Thanks for you interest (and skulls).
Whats done, Whats left
08/21/2014 at 05:39 • 0 comments-----------------
Whats Done
Temperature/Humidity sensor data collection
Soil moisture sensor data collection
Relay/valve control code
Wireless data link - Only wifi and still need to be optimised but its functional
Solar Node
Base Station Display (LCD)
Whats Left
Meshing nodes
151MHz radio links
Wireless Hotspot
Data encryption
User rights
User Interface
Button Interface
RTC sync signal
Automation Program Repository (Website)
Its all about permaculture
08/21/2014 at 03:38 • 0 commentsAt the core permaculture is optimisation of those processes by which natural systems feedback against each other, to create a pattern of energy exchanges that benefits us.
This generally takes the form of connecting mutally beneficial systems together and composting...
This is what GoT is all about, connecting systems (in this case sometime very distance systems) by data. To allow the equipment you have to perform mutally beneficial tasks and minmise your own need to apply disproportionate work to any system. And maximise your yield, whether that be carrots or cash.
Hydro Power
08/21/2014 at 00:44 • 0 commentsWill be adding a water turbine generator on remote reticulation nodes that will be powered by water flow (from a pressure pump or mains water supply)
A small solar panel will keep a battery charged for powering the node and providing power to open the solenoid valve (24V 0.43A). When the valve is opened the water flow will run the turbine to keep the valve open(24V 0.25A) as well as charge the battery.
In this way only a small solar panel will be required to keep the battery topped up when the node is in standby mode.
Solar Node
08/20/2014 at 10:11 • 0 commentsDo a bit of testing using an old solar light to run a remote temperature sensor node.
The case from the solar light will serv very well as case for the node electronics..handy.
Ready to Begin
08/07/2014 at 09:46 • 0 commentsAll the components have arrived. I've started basic functionality testing by creating a wirless reticulation node.So wireless and relay control code is out of the way, now its only everything else to go.
Peter
