To print accurate parts for the new Prusa i3 Mk2 clone, I need to make sure that my old PrintrBot clone printer is dimensionally accurate, so I start by recalibrating the firmware on my old printer.
How to setup Marlin Firmware
- 1:27 Constants: Board Type, Printer Type, Printing Area, Belts/Pulleys, Steps per mm, Hot End, Heated Bed
- 3:20 M501 command will print most of the parameters
- Marlin Firmware & Arduino at marlinfw.org and arduino.cc
- 4:26 Open marlin.ino with the Arduino IDE. Go to configuration.h tab
- 4:40 Start of configuration.h options, pre-built available in the example_configurations folder
- (todo: continue watching this video)
Steps per milimiter
Calibrating your extruder
BlueFlower
Hulk
Andrew Dawes
There are clones of printrbots? I thought they were as cheap as possible already :D
