1Step 1
Many project construction details are on our website l0l.org.uk. Here I'll just quickly outline how to make a v2 base-station and a single wireless sensor, you'll also need some more software from our git repositories.
2Step 2
Assemble a base-station from a Raspberry Pi B+, sd-card, power supply and rfm12b dongle. You can use a JeeLink or a directly connected board.
3Step 3
Download the thingbox.io image to the sd-card and boot the Pi. If you're using a direct connection you'll have to enable SPI and install the drivers - instructions here.
4Step 4
Configure your Raspberry Pi as per the thingbox instructions and load our flows from git into Node-RED.
5Step 5
Assemble a wireless sensor from a JeeNode v6 and a battery. You'll need a few extras like a case and battery connections, and of course a sensor (I like waterproof DS18B20's). Connect up the temperature sensor (don't forget the 4.7k resistor between Vcc and DQ) and optionally, a battery monitoring circuit.
6Step 6
Load in our 'configurator' sketch from github and use the serial terminal to set the ports you wired the temperature sensor and the battery monitoring sensor into.
7Step 7
Now load the main aquaponics sketch and customise it so that the delay period is as required - every 5 seconds will give you poor battery life - every 60 seconds is more reasonable. Once the sensor sketch is uploaded you should see reading appearing in the Node-RED screen of the Raspberry Pi
