1Step 1
Board assembly - SMD
- Manually apply solder paste
- Place surface mount components on top using tweezers
- Heat with hot air to reflow solder
- Repeat for bottom layer components
2Step 2
Board assembly - through hole
- Install and solder connectors (Jx), switches (SWx), and MD4 (CO sensor).
- Solder super capacitor (C7), trim leads short.
- Ensure MD1 has been programmed (ESP8266).
- Solder MD1 and MD2 modules (wifi and uSD).
- Solder MD3 module (MH-Z19).
Thomas
