New alignment between lanes is shown below;
I have assumed backlash is zero
The width of a scanline is 5.54 mm, still I use 5.4 mm in reality, to achieve stitching.
Results look pretty good. Should be more than sufficient for PCBs.
A project log for prism laser scanner
bringing additive manufacturing to the next level
Please add a picture of a closeup of the 70um part. JPEG compression makes it look like a solid block.
You are right!! Should have made a picture with a close up... maybe once I have a PCB image
