Arduino Mystery Box
Learn how to create your own Mystery Box, that will open only by interacting with the three inputs.
Hello!
This is a tutorial for beginners, that will help you create a "Mystery Box" that will only open after using all three inputs (HC-SR04 Ultrasound sensor, Photoresistor, and an NTC Thermistor).
This is a fun 4-step Mystery Box that you make at home, to entertain your friends or family.
You would have to interact with the three inputs of the Arduino in order to open the lock.
The SG90 Servo will only open when all 4 steps are completed.
Step 1, after powering the box.
JPEG Image - 3.31 MB - 05/11/2017 at 13:36
Preview
The inside of the box, with the SG90 Servomotor and complete wiring.
JPEG Image - 3.01 MB - 05/11/2017 at 13:36
Preview
Another close-up of the inside of the box.
JPEG Image - 2.82 MB - 05/11/2017 at 13:36
Preview
Right side of the box with HC-SR04 Ultrasonic Range sensor and NTC Thermistor 10kohm.
JPEG Image - 2.35 MB - 05/11/2017 at 13:36
Preview
Left side of the box, with the PhotoResistor and the Power supply + Arduino USB port.
JPEG Image - 2.73 MB - 05/11/2017 at 13:36
Preview
View all 9 files
  • 1 × Arduino UNO
  • 1 × HC-SR04 Ultrasonic Range Sensor.
  • 1 × Photo resistor
  • 1 × NTC Thermistor 10kohm
  • 1 × Breadboard (generic)
View all 11 components
  • 1
    Step 1
    Hello!
  • 2
    Step 2
    After gathering all needed items, you can wire them like I did in this Fritzing Diagram:
    For the NTC Thermistor I used a 10k resistor.
    For the Photoresistor I used a 5k resistor.
    You can use regular 220 ohm resistors for the LEDs.
  • 3
    Step 3
    You can position the "sensors" how you'd like it the most in the box, but for me, this was the most easy and effective way.
View all 5 instructions
ravicena187 wrote 10/21/2020 at 01:09 • point
thanks for the great article loved it Your post is amazing .It helped me a lot in my research. https://www.propacity.in/blog/real-estate-marketing/
Caren Acquaviva wrote 01/24/2020 at 09:35 • point
Cool, I want it in my store. Write me https://gym-expert.com/
simplisiti wrote 12/27/2019 at 04:56 • point
Hi ! very interesting project! I am a beginner, and would like to ask, how do u determine the values of the resistors?
