This is a fun 4-step Mystery Box that you make at home, to entertain your friends or family.
You would have to interact with the three inputs of the Arduino in order to open the lock.
The SG90 Servo will only open when all 4 steps are completed.
Learn how to create your own Mystery Box, that will open only by interacting with the three inputs.
20170507_220539.jpgStep 1, after powering the box.JPEG Image - 3.31 MB - 05/11/2017 at 13:36 |
20170507_223536.jpgThe inside of the box, with the SG90 Servomotor and complete wiring.JPEG Image - 3.01 MB - 05/11/2017 at 13:36 |
20170507_220847.jpgAnother close-up of the inside of the box.JPEG Image - 2.82 MB - 05/11/2017 at 13:36 |
20170507_223159.jpgRight side of the box with HC-SR04 Ultrasonic Range sensor and NTC Thermistor 10kohm.JPEG Image - 2.35 MB - 05/11/2017 at 13:36 |
20170507_223108.jpgLeft side of the box, with the PhotoResistor and the Power supply + Arduino USB port.JPEG Image - 2.73 MB - 05/11/2017 at 13:36 |
Hello!
This is a tutorial for beginners, that will help you create a "Mystery Box" that will only open after using all three inputs (HC-SR04 Ultrasound sensor, Photoresistor, and an NTC Thermistor).
After gathering all needed items, you can wire them like I did in this Fritzing Diagram:
For the NTC Thermistor I used a 10k resistor.
For the Photoresistor I used a 5k resistor.
You can use regular 220 ohm resistors for the LEDs.
You can position the "sensors" how you'd like it the most in the box, but for me, this was the most easy and effective way.
Cool, I want it in my store. Write me https://gym-expert.com/
Hi ! very interesting project! I am a beginner, and would like to ask, how do u determine the values of the resistors?
thanks for the great article loved it Your post is amazing .It helped me a lot in my research. https://www.propacity.in/blog/real-estate-marketing/
