Led
Led cooling
Led driver
LiPo battery
LED reflector lense
Aluminium case
Poti to adjust Brightnes
Led
Led cooling
Led driver
LiPo battery
LED reflector lense
Aluminium case
Added a fucusable Lens and low noise Fan
Next update will be a ultra low noise fan (19 dB or less) and batterycontroll. The batterycontroll is relevant to stepup converter. that means the electric circuit of the batt.controll will be added to the el.circuit of the step up converter.
or just search around your city, if any company is processing metal. Just ask them
Where did you source the aluminum case?
