As I wrote earlier, TB 2.0 (rc1 for now) has the ability to use different keyword sets in any single-byte encoding. If you are a TB user and if you consider useful some alternative keyword set in your native language, it can be included in future release of Terminal-BASIC. Now there was created a Russian keyword set, based on such, used in BASIC-6 system for БЭСМ-6 mainframe.
English |
Русский | French |
AND |
И | |
DATA |
ДАННЫЕ | |
DEF |
ОПР | |
DIM |
РАЗМЕР | |
END |
КОНЕЦ | FIN |
FN |
ФУНК | |
FOR |
ДЛЯ | POUR |
GOSUB |
ВХОД | |
GOTO |
НА | |
IF |
ЕСЛИ | SI |
INPUT |
ВВОД | LIRE |
LEFT$ | ЛЕВ$ | |
LEN | ДЛИНА | |
LET |
ПУСТЬ | |
LIST |
ЛИСТАТЬ | LISTER |
MAT |
МАТ | |
MID$ | СРЕД$ | |
NEXT |
ЦИКЛ | |
NOT |
НЕ | |
ON |
ПРИ | |
OR |
ИЛИ | |
ВЫВОД | AFFICHER |
READ |
ВЗЯТЬ | |
REM |
КОМ | |
RESTORE |
СНОВА | |
RETURN |
ВОЗВРАТ | RETOUR |
RIGHT$ | ПРАВ$ | |
RUN |
ПУСК | |
STEP |
ШАГ | |
STOP |
СТОП | |
STR$ | СТР$ | |
THEN |
ТО | ALORS |
TO |
ДО | JUSQUA |
To answer the question in your title: Yes!
BASIC is a great language for beginners but having to work in a second (or third, or fourth) language while one learns is counter-productive. This is great :)
Yes, I found native keywords set useful when I started to teach my 5 years old daughter some BASIC programming. It's hard to explain her both English and BASIC languages at the same time.
I will try to add French keywords, based on LSE (https://fr.wikipedia.org/wiki/LSE_(langage)) language
