First enclosure
08/13/2014 at 22:41 • 0 commentsThe project isn't moving on as fast as I wanted to, others things got in the way...
I finished the print of the first casing for the parachute, based on rough dimensions I took from the parachute, and I made it waaaay too big... Lesson learned.
It took 18 hours to print, but it allows me to make sure my system works correctly before making the definitive casing.
First parachute tests, description video
08/07/2014 at 12:36 • 0 commentsI just came back from my testing facility (ok, I just tossed the parachute from the highest window of my house), and the results seem pretty interesting: with a 500g load, the parachute slows down to about 2.5m/s, and with a kilogram, the speed is still decreased to 6-7m/s, which is slow enough to avoid major damage.
Now that I know how big the parachute needs to be, I'll fold it up correctly and size the compartment.
I also made a small presentation video to hit the requirements for the Hackaday Prize. Gosh, listening to myself makes me realise how terrible my english actually is...
Parachute tests
08/07/2014 at 11:24 • 0 commentsAfter sizing the parachute I needed, I took some plastic sheet I had lying around and cut it into a circle of 45cm in diameter.
I then attached 4 strings, making them into eight parachute lines:
The mock-up is ready for some testing. It will allow me to check whether I have enough suface to slow it down, and size up the compartment that will hold it when folded.
First thoughts
08/01/2014 at 19:46 • 0 commentsI want a system that has the following requirements:
-Be able to install easily on a any kind of multicopter (sub-750g)
-Be lightweight (Under 50g would be great, I still need to figure out how light this actually needs to be)
-Be cheap (If not under $10, at least under 30 bucks)
-Be totally independent from the main system: I want something that deploys the chute when it detects an abnormal drop in altitude (or a g-variation, I have both sensors)
The first thing I have to figure out, is how big the chute needs to be. If I follow a matching table (on page 17 of this PDF: http://www.planete-sciences.org/espace/publications/techniques/parachutes.pdf ), I need a spherical parachute of 43.8cm in diameter to slow down a 1kg body at 10m/s. Now, we will be braking only 750g, but I want it to be slowed down a bit more, so I'll round this diameter up to 45cm.
With this in mind, I'll first make a mock-up of the chute using simple trash bags, to get a feeling of how big the compartment needs to be.
M.daSilva
