First PCB Batch
06/05/2017 at 19:50 • 5 commentsSo the first prototype batch after a bit rework og the pcb design.
The RTC is now directly on the board, so no other components needed.
I ordered 15 pcb by firstPCB and hopefully they will arrive in a week.
The next step is to create a 3d printable case. The pcb size is a bit larger (90x80mm) but this will fit into a 100x100mm case.
MOVED TO EAGLE
06/04/2017 at 00:00 • 0 commentsSo, i have switched to eagle, because i had some issues with my kicad installation.
The first pcb layout is ready to use. Checkup the GitHub repo (/src/bin_clock_eagle/)
ADDED SCHEMATICS
06/03/2017 at 14:35 • 0 commentsNow, im currently working on a simple pcb for this binary clock.
The pcb will contain all parts including the ws2813b leds.
The RTC module is connected via a pin header socket.
Please see the KiCad project on the github page (/src/simple_bin_clock_kicad)
