6lowpan home sensors
Small, general purpose development boards for connecting sensors to an IPv6 network
  • 1 × Atmel ATMEGA128RFA1 Microcontroller with IEEE 802.15.4 transceiver
  • 1 × JOHANSON TECHNOLOGY 2450FB15L0001E 2.4Ghz 50Ω Balun
  • 2 × AVX 06035A220JAT2A 0603, 22pF 50V, RF coupling
  • 1 × TE CONNECTIVITY 5-1814832-1 SMA straight panel mount jack
  • 1 × VISHAY DRALORIC CRCW060330R0FKEA Current limiting resistor for LED
View all 14 components
Rich text editor
Matthew Wilkes wrote 08/07/2014 at 11:56 point
I am planning to add more soon, yes. There are lots of project logs I need to upload.
I've got some running Contiki and some running Arduino. I've been having some trouble with the radios which I'll be debugging next week once my HackRF arrives. The reason they're not all on Contiki at the moment is that I only have one UART exposed to the USB interface meaning I need to use an extra FTDI to get both the network and log channels from Contiki. When running under Arduino I can prototype things easily which is important for getting sensors to work. The bus power is only 1.8V and they need a good battery life, it's easy to waste amps.
Jasurbek wrote 08/07/2014 at 11:52 point
Very nice project, please share more info about it. Thank you.
Can you run Contiki OS, TinyOS or similar OS on it?
