I am planning to add more soon, yes. There are lots of project logs I need to upload.
I've got some running Contiki and some running Arduino. I've been having some trouble with the radios which I'll be debugging next week once my HackRF arrives. The reason they're not all on Contiki at the moment is that I only have one UART exposed to the USB interface meaning I need to use an extra FTDI to get both the network and log channels from Contiki. When running under Arduino I can prototype things easily which is important for getting sensors to work. The bus power is only 1.8V and they need a good battery life, it's easy to waste amps.
