I plan to transfer this LaTeX file over for the description, but in the mean time here is the build log as a .pdf!
Long story short, I utilized a cheap Bluetooth module to add H2DP connectivity to my car radio.
Since I am new to all this and Arduino, I am having trouble sending AT command to this module. I have no idea what they are and how to send them. I need to change the name of my module. How do I do that? I also want to increase the volume of my module through AT commands as the push button system isn't working and my module volume is set low. And is there any way to increase the range of this module? Please answer my questions regarding AT commands in a detailed manner so that I would be able to understand them, the rest can be brief. Also, is it possible to send AT commands via Arduino. And please tell me how to use mic with this module.
Hi everyone,
I just want to ask something, I am creating a Bluetooth speaker using a xs3868 but I can't get it to work... I released the same wiring than you, but I can't detect the chip with my phone, the led stay off, and I just can hear a type of static in the left channel. So a few questions : what did you have done when you say "After various tweaking" (P.3 of the PDF) ? I precise that I did not used the serial to set the chip, is it absolutely necessary ? Oh and when you say "the module refuses to start back up [...] source pins shorted", which pins exactly ?
Thanks a lot man, good luck ! :D
You don't need to setup the module via the UART for it to operate. I believe there is multiple pinouts of the XS3868. Maybe you have a different module? I did this about 2 years ago.
When I said "source pins" I was referring to Vcc and Vss I think. I've had the final circuit installed in my car radio for about two years. "Various tweaking" I believe was me double checking all my connections.
Sorry I couldn't be more helpful! : ( You can look up the datasheet for the IC and trace the pins to make sure your module has the same pinout?
Thanks for your help, I checked all my connections and it seems the "voltage divider bridge" I made produce only 2.3V, so I will correct this first. Then I'll try what you say, I hope this will help me :D
Thank you ! :D
Hi Tyler, sorry for being late.
I finally was able to correctly power the device, using a few resistors to correct the tension from 12 to 3.6V. When I turn on the system, I can hear a little sound "ding ding ding" and the LED turns on during 1/4 second. But after that, I can hear a lot of parasites, a sound like the "iiiiiiii..." of a tube TV. The problem is that the device is not discovered by my phone, so I think it doesn't work correctly... Do you think I should use a LM317, or the problem isn't there ? I think about it since June and I haven't found yet the solution ! :(
Thank you for your help, I hope you will be able to miraculously help me ! X)
ZP
Hi buddy ... :)
firstly, thank you for this post ..
secondly , I have a question my friend ..
Is there any way to send the name of a contact and make call to that name by xs3868 ?
I had this issue. It depends on the set of AT commands loaded into the XS3868. It either comes with the firmware or it doesn't. I ordered a bunch of one later which are "suppose" to support that feature, but I never got around to checking it out.
Did you ever manage to get SPP working with this device?
No. I don't believe the module had the SPP profile loaded into the EEPROM. I order a few additional modules a while back. Which are suppose to support additional profiles. I'll let you know if they have SPP.
I tried to access the drive link, but it says: "We're sorry. You can't access this item because it is in violation of our Terms of Service." Is there any other way to get more details about thisproject? I have a Mazda 3 car and I want to integrate BT audio into the car.
In a comment in 2014 you mentioned that you'd ordered additional modules that claimed to have different BlueTooth profiles, did you ever get these modules and did any of them have the HFP (handsfree) profile?
You also mentioned that you might be able to dump the EEPROM for the different modules and compare them, did you ever get round to that and if so do you have a link to the EEPROM dumps?
