68030 Based home computer using once top-of-the-line parts
Sadly, I hit some supply chain issues with some of the parts after I started the routing process for the board. I'm most likely going to wind up replacing the YM chipset with something else since finding the OPL4 is near impossible to very expensive now. My new approach will probably be to use the SNES audio hardware (the one chip version) if I ever finish making a breakout board for it. IT actually frees up a lot of space on my board and makes routing it to a mini-itx form factor much simpler.
Hi! The spec for your 68030 system is interesting. I'm building up to a similar project at the moment - currently finishing off a 68010-based system (listed on my project page, if you're interested). Have you made any progress with your system since you posted your spec?
Any progress?
