Step 5: Installing and Using the Seafile Server Software
A project log for Linux Tutorial: Odroid U3 Server w/ Seafile Cloud
I posting this to give a feel for the Odroid U3. There is a forum but not a lot of documentation out there.
tlankford01tlankford01 • 08/06/2014 at 02:17•0 Comments
There are two dependencies that the software may ask for during install so we are going to preempt this error by installing the last of the prerequisite software libraries.
type the command:
sudo apt-get install python-setuptools python-simplejson
Answer y if prompted
Now we are ready to install the Seafile Server. This will allow a nice interface to your server through your browser window.
Let's first create a directory seafile by the following command:
mkdir seafile
then change directories:
cd seafile
now we are ready to download the package into the directory seafile:
wget hhtps://bitbucket.org/haiwen/seafile/downloads/seafile-server_3.0.4_pi.tar.gz
and untar the package:
tar xzvf seafile_server*
change directories:
cd seafile_server*
then install the software:
.setup-seafile-mysql.sh
you will follow the prompts here and just choose defaults except for two things:
when asked for server name choose you server name
Enter your IP address
choose the default ports but then you want to direct the data to your drive you setup earlier. My drive path is /media/odroid/labserv/seafile-data
Choose to setup new mysql databases. After all the questions are answered you should have a setup list that looks like this
Server Name: Your Server Name
IPAddress: Your IP
ccnet server port: 10001
seafile data: /media/odroid/labserv/seafile-data
seafile server: 12001
HTTP server: 8082
MySQL server: 3306
ccnet database: ccnet-db
seafile database: ccnet-db
seahub database: seahub-db
During the setup you may be asked to enter to the mysql root password you set earlier
Now we are going to start seafile server and seahub first type the command:
./seafile.sh
It should start and tell you it is ok then type:
./seahub.sh
you should be asked to enter the administrative email which should be any email you want and then set a password for the browser login just enter those and remember them. The Seahub should setup for the first time and run fine. You can now check it in your chrome browser by typing:
http:yourip:8000
just login and check out your new cloud server
