Server Side
A project log for sat.Send
sat.Send is a small device that allows you to send and receive messages and share your GPS location no matter where you are.
john-grantJohn Grant • 08/17/2014 at 21:05•0 Comments
Meteor is an open-source platform for quickly building web apps. Both server and client code is written in Javascript and the framework is designed to be responsive and has a great community. I'm going to write a web app that logs the messages that have been sent to/from the device and it will also show a real time map of location points.
