Initial Yun Client Code
A project log for sat.Send
sat.Send is a small device that allows you to send and receive messages and share your GPS location no matter where you are.
john-grantJohn Grant • 08/18/2014 at 20:40•0 Comments
Using code from a previous project as the basis for the Yun client. This code is added to the GitHub satSendClient link. The code is a basic webserver for an Arduino Uno and includes basic network setup, page routing and HTML. A lot of this code will be easily altered to work on the Yun so forms a good starting point.
