1Step 1
Starting with the shelºF Act unit, connect the April Board and the 2 Channel Relay Module by wiring VCC to the imp's VIN, GND to the imp's GND, IN2 to the imp's Pin1 and IN1 to the imp's Pin2
2Step 2
For the shelºF Sense TempBook board, solder all the components on the PCB as specified by the schematics
3Step 3
Connect the heating, cooling and ground wires to the relays and power the shelºF Act unit using the usb port.
4Step 4
BlinkUp the Electric Imp devices which will add them to your Electric Imp IDE
5Step 5
Download the app and imp code and follow the app instructions to quickly setup the system
6Step 6
Place your TempBook board on a book (or anywhere) and enjoy your new Home Comfort Control System!
Juan Albanell
