Log two: The circuit is made
08/19/2014 at 11:00 • 0 commentsNearly fnished soldering the circuit on perfboard. Resistors are hooked up to the arduino and then a ribbon cable. A Johnson counter and a Darlington transistor array are also attached together and then to the duino and ribbon cable. The cable then goes to the cube and is connected via female headers. Just a little more to do before I can test.
Log one: the LEDs are soldered
08/08/2014 at 10:40 • 0 comments96 blue leds soldered together using a card template. My god this was time consuming But the cube is finally finished. Or so I thought. I then went to test some Leds and had my psu set to its highest seting by mistake. I had to order more leds and have now replaced the dead ones.
Kid Iccurus
