Update for new followers
10/28/2015 at 22:34 • 0 commentsSo, I've been working on this off and on for the last year or so, been through three major iterations, and I'm considering a fourth. I've reached all my goals for size and features. The current case doesn't have button pushers, but the switches are there under the surface. The case is 40x40mm, and 7mm thick, excluding the lugs. That could go down as low as 37x37x6mm with thinner plastics, but there's a limit to what my printer can manage. I might have something printed in steel or brass, I think that would be nice. More info, including a new BOM, can be found at http://ourglass.watch.
General status update
08/11/2014 at 19:59 • 0 commentsI've posted a little about the reflow oven I've built in order to actually build this thing here on the blog. Also, a general status update is here (also the project blog). It's still pretty rough, but hopefully I'll have more updates in the next few days.
Matt Mills
